Thread: door lock problems
    423 KING
    Chattanooga, TN
    Default door lock problems
    I was wondering if anybody else has had problems with their power door locks. The actuator seems to get hung up when i try to unlock the door with the key and with the switch. I cleaned it with some wd40 and it worked fine for a few days. Went and had my new keyless entry and alarm put on this morning and it starts acting up again. Thanks
    18x9 +24 18x10+22
    Новак 5speed's Avatar
    Conyers, GA
    Remove the door panel and lock the the door, then unlock it both ways and see whats the deal.
    Amen.
    423 KING
    Chattanooga, TN
    Did it a few times, i thought it was bc the clips that hold the rod in place that goes from the switch to the actuator were broken. but it works with the rod in or out of the clip. i cant see anything wrong with it lol
    18x9 +24 18x10+22
    morethanmeetstheeye imperception's Avatar
    Oct 2009
    is homeless
    Quote Originally Posted by lanning View Post
    The clips don't keep it from binding, that was always my problem...no clips
    Please repeat after me: "EVERY part on my car is OEM, OEM JDM, or NAME BRAND. NO FAKE PARTS IN OR ON MY CAR. One way, one time, done right."
    423 KING
    Chattanooga, TN
    what i dont understand is it doesnt do it all the time its only every once in awhile
    18x9 +24 18x10+22
    Oct 2009
    is homeless
    it's possible the relay box is getting old on you. Relays do wear out over time causing a shortage in current/voltage to solenoid...OR, could be simply the motors wearing out...if you have a volt meter, test the INPUT at the actuator itself and flip the switch and see if you find any inconsistency.
    CHECK for proper signal/voltage/current at:
    output of keyless entry
    input at relay box (OEM)
    at input of actuator/solenoid
    ALL SHOULD BE 12V
    423 KING
    Chattanooga, TN
    thanks, im thinking about taking it to the shop that did my alarm and seeing if the actuator is bad
    18x9 +24 18x10+22
    Oct 2009
    is homeless
    ever near Athens I'll do that shit myself...
    423 KING
    Chattanooga, TN
    Quote Originally Posted by imperception View Post
    im gunna try to come meet up with all of yall one weekend but its a long drive from tennessee
    18x9 +24 18x10+22
