Thread: b18 connecting rod bearing, is quite loose..What to do?
    SwiperNoSwiping!!
    Default b18 connecting rod bearing, is quite loose..What to do?
    The stock spec for the b18a rod bearing oil clearance is supposed to be between .0008" and .0015", and all of the bearings so far have met clearance within specifications, slightly on the loose side of things though. Until, connecting rod #3; its bearing clearance is looking closer to .002" than anything. What should i do, would it be safe to run it like that or is it an absolute must that i get an oversized bearing for that journal to bring the numbers within spec?
    u remind me of a wigger !
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Get oem bearings and just the color code chart.
    West palm beach
    needs to be in spec...
    NO ADVERTISING
    -IA MANAGEMENT
    SwiperNoSwiping!!
    UPDATE: i just re-did the plastigage on that journal, just to make sure, and this time around it came out nearly perfect. The plastic was crushed slightly flatter than .0015 but not so big that it fit in the .001.
    Double checking my work????
    SwiperNoSwiping!!
    Quote Originally Posted by slow_hatch View Post
    yup! lol
    also, i had to put the ARP connecting rod bolts in there, i figured why not check everything
    yup! lol
    lol, I agree. Everything checked out when we did it.
    SwiperNoSwiping!!
    checked out here too, y'all did a good job buildin it
    I personally measured all the bearings on the build and recall them being in spec.. make sure the crank doesn't get rotated or the caps get shifted when installing them or it can throw the measurements off.
    if you measured once and its off spec, and then measured again and its within spec... your doing or did something wrong, or you cant measure lol
    Jul 2009
    your good
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    check recheck and double recheck. an ounce of prevention is worth a pound of cure.
