Results 1 to 21 of 21
Thread: cams? headgasket?
    Default cams? headgasket?
    so im putting together my kit and im practically done, besiedes the small things like oil lines, gauges, etc . so anyway, im upgrading pistons, rods and bearings, so i wanted to know if i have to upgrade my cams as well?
    and any advice on what kind of head gasket i should use?
    any input appreciated
    damn, i want that penis
    IA's Pedo-cord tdurr's Avatar
    Fayco
    cosmetic HG, and how many lbs are u planning on running? I kno u got arp headstuds planned out already so dont gotta worry about that...and a cam can never hurt. What powerband are u looking for? diff cams have diff ranges and some are made for turbo apps only.
    Save ur engines!
    Northwest Georgia
    you don't have to upgrade your cams and USE A STOCK HEADGASKET PLEASE!!!!
    www.jjspec.com Macon, Ga
    ^^^What he said. I made 800on a stock set of cams, cam gears and head gasket.
    thanks for the help guys! reps to ya!
    any gaskets have to be aftermarket? planning to get everything OEM
    Northwest Georgia
    no, use all OEM, there are no performance gaskets so far that surpass the oem quality, but really the head gasket is the only gasket that needs focus. I guess the Golden eagle intake manifold gasket would be the only other gasket i would use, you can reuse it and it actually comes off the had when you remove the manifold: its worth its weight in gold.
    known as Charles
    Quote Originally Posted by SPOOLIN View Post
    X2
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    OEM gaskets only, I have used cometic gaskets with good results but why, when a OEM gasket is as good if not better. I went to EFI University back in the day and one of the classes was on using a "thicker" headgasket to lower comp. Which is why alot of people will buy something like a cometic over a stock. They said that when you do that it can actually mess with the combustion chamber design enough to cause small hot spots. This in return can cause detonation, pre-ignition, burnt valves etc...
    Ok OEM it is! Have another question, I currently have a skunk2 intake manifold on my gsr, so my question is would it be better for me to use a jg mani? I'm not planning on reving past my 8k redline and I know skunk2 IMs make power between 4-8k I believe and the jg from like 7-11k.
    Jul 2009
    i have a skunk2 on my ls..... i noticed mid range power.....
    just curious were you the guy who rolled by tonight when i was stopped???
    ^^ yea the mid range power gain is noticable compared to the oem manis. And naw it wasn't me, my car was taking a rest today.
    Jul 2009
    i got my turbo setup done...... i notice more top end power now though.... lol
    ^ lol well that's always good. What kinda of setup are you running?
    the skunk2 will be fine.
    Jul 2009
    t3 t4 with cast manifold.
    2.5 exhaust
    660 cc injectors
    fmic
    obd1 ecu on chrome
    38mm wastegate
    ssqv bov
    and destroked b18
    Sounds good man. So u rebuilt your motor with stock internals? And where did you get crome? That's what I'm planning on using as well
    Jul 2009
    Quote Originally Posted by marcos713 View Post
    no i got eagle h beam gsr rods and je gsr pistons with gsr crank in an ls
    i got my ecu thanx to ebay for 115 chipped socketed with chrome
    ~TeamGhostRiders~
    Eatonton, GA
    i like cosmetic
    Nice setup. how long did it take to tune?
    Quote Originally Posted by dallasb84 View Post
    Norcross
    Quote Originally Posted by motoman32002 View Post
    i like cosmetic
    u do makeup?
    ^lmao!
