Results 1 to 26 of 26
Thread: What plugs for turbo Honda?
    revolution big mac's Avatar
    Default What plugs for turbo Honda?
    What are the best spark plug to run Ina turbo honda18psi?
    West palm beach
    NGK BKR7E-11 gapped at .28
    NO ADVERTISING
    -IA MANAGEMENT
    u can get the plain bkr7e's too. i think the only difference is the bkr7e-11 already come pre-gapped. i run a .30 gap.
    B-Town Crunk Force
    Statesboro, GA
    ngk bkr7e's for the win.
    and bishes are cheap too
    thats what i ordered a few minutes ago along with ngk wires. the ngk website says that these plugs are obsolete haha
    Ngk, bruh!
    Around metro-ATLANTA & IA!!
    PERFECT!! A+
    Good for nitrous too...
    140 on one wheel
    columbus, ga
    the 7's are only good up to 450-500whp
    www.jjspec.com Macon, Ga
    Quote Originally Posted by -S Double C- View Post
    Not to dispute you, but I know of a certain 600+whp car using a set of 7's. I keep the 7, 8 and 10's in stock.
    On a side note, LongLiveH2B has SOHC Power in his sig. Explain, please.
    thats what i used to rub in my sc cobalt but i just wasnt sure if there was anything better out there for hondas
    Senior Member EJdm's Avatar
    how about for a stock b-series with I/H/E...jw
    you can run the bkr7e-11 or bkr7e just the gap would have to be more than.28
    Quote Originally Posted by EJdm View Post
    You can run the 6 heat range. The 7's will probably be too cold for you and present some fouling issues.
    thanks...i usually just get the NGK IX Iridium Spark Plugs...
    known as Charles
    Quote Originally Posted by big mac View Post
    The 11 means that they come pregapped at .044". I am not sure what the gap on the bkr7e will be but in either case you need to gap them at .028" like everyone has said. The 7 heat range will be fine for the power you are looking to make. Also, you can normally get the 7s at the autoparts stores but the 8s and up have to be ordered.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    Northwest Georgia
    number 7's for up to 600, after that they will still work but i would recommend a 9. I run the iridium 9's.
    140 on one wheel
    columbus, ga
    ^^^brp9eix's?
    Northwest Georgia
    bkr9eix
    dc5
    ATL, GA
    iridium ngk 9s or 8s
    Certified Gearhead wwli's Avatar
    Anyone run that new E3 plug for boost?
    I am also running the BKR7E (#6097)as well but I saw HP TV used this plug and it gained HP and better emissions however it was on an N/A car so I was hoping if someone had any experiences with it.
    According to their plug guide BKR7E-11 = E3.64 and since we can't re-gap them I am not sure if this will work or not.....just something new to try
    Thanks
    EK needs a new tune? baby needs more boost so a good tuner is needed....anyone?
    E3 is garbage. I ran those plugs in my car and they made my car run terrible. I went back to the NGK plugs, and I will never run anything else other than NGK.
    cust brought his car in to be tuned and the plugs were garbage. swapped back to bkr7e and gapped them and he is all good.
    Northwest Georgia
    Quote Originally Posted by wwli View Post
    Thanks
    you can re-gap any spark plug.
    ^^^ This style of plug may not be "gap-able", maybe if you measured all 3 on each plug.
    Super Dave Z U L8R's Avatar
    Roswell
    bkr7e @ .028 , NGK Part Number #4644 $1.89/ea. ftmfw
    they usually come at .030-.032 which is fine for boost lower than ~12psi depending on the ignition system, at 22psi i've never blown out spark when gapped to .028
    we've dynotested the capacitor type spark plugs in a 350z and made more with regular plugs, wasn't much but $1.89/per plug is better than 25 bucks EACH lol.
    i'll z you later josh green ^^ traction ftmfw
    Dave
    I ♥ Sluts
    Henry Co.
    I was tuned and been using the NGK part number 4091, R5671A-7 for over a year now. I gap them to the width of one of the metal prongs on your 20 amp regular fuse.
