Results 1 to 19 of 19
Thread: sputtering problem
    Jun 2009
    marietta
    Default sputtering problem
    i have a 91 acura interga its has a sputtering problem when i drive it for about 15 min it runs fine but after that it starts to sputter in avery gear i have changed the spark plug and spark plug wires and still no change plz any help?
    ChanTheMan
    DA SQUAD#57
    vanilla sky.
    what do you mean by sputter?
    Jun 2009
    marietta
    like when it hits 3000 to 4000 rpm it starts to put put lol like gas is not getting into the engine or something it looses power
    ChanTheMan
    DA SQUAD#57
    vanilla sky.
    is your check engine light on?
    Jun 2009
    marietta
    yea
    ChanTheMan
    DA SQUAD#57
    aye bro .:Stirfry:.'s Avatar
    check your vac. lines leading to the map
    ATL DAsquad Member #9
    Certified Gearhead 91boostdgsr's Avatar
    Jul 2009
    Griffin, GA
    Quote Originally Posted by .:Stirfry:. View Post
    x2
    INSERT SIG HERE>>>____________________________
    i used to unplug mine way back in the day, to act like i had a 2step setup.
    lol..
    Jun 2009
    marietta
    hey thanks imma try that
    ChanTheMan
    DA SQUAD#57
    check your fast idle valve and have you checked you distibutor cap and rotor button
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    Jun 2009
    marietta
    i havent check the fast idle valve yet but i will be replaceing the distibutoit cap and rotor this weekend thanks for the help.
    ChanTheMan
    DA SQUAD#57
    DO WORK SON
    augusta GA
    might have a clogged fuel filter... trash in the gas tank, faulty tps..... check the codes on your ecu.... long beeps are 10 short beeps are 1... get on google and look up the CEL codes....
    ps3 gamer tag:drift_supra add it
    89 conquest TSI
    TRACTION CONTROL IS FOR PUSSIES.
    rollin 91 da egpower904's Avatar
    Dallas, GA
    my eg8 did this exact same thing, i replaced everything i could think of and then some. did all the above that everyone said. it was my o2 sensor on the header, was completely shot. check that man.
    Jun 2009
    marietta
    hey thanks for the info i will be checking these things soon
    ChanTheMan
    DA SQUAD#57
    THAONLYDAW/SISEATS
    Winder
    yes check all of the above also check fuel pressure..... could be the pressure regulator.... the main fuel relay and also check all of the ground wires.... motor to frame trans to frame and it helps to make a couple more
    NW Boonies
    injector..
    juss sayin.. had the same problem.
    take a long flat head screw driver and put the tip on each one of the injectors to see if u can hear each one of them clicking while the car is on. when u find the one that isnt ticking, lmk lol!
    ~DB4LYFE
    07 Honda GD3
    DO WORK SON
    augusta GA
    try and see if the rotor button is wobbling, sounds stupid but just double check that too.
    89 conquest TSI
    THAONLYDAW/SISEATS
    Winder
    y use a screw driver to check injectors..... multimeter......just sayin.......and could possibly be the dizzy.... it has three sensors in it... one of mine went out and the da sounded like a scooby.....
    Dallas, GA
    where you located? if you cant yourself, a local tuning shop would be able to help you weed it out if its throwing codes. they're kinda tricky with da's not being obd2 wich uses a simple plug and play scanner. have someone run your code and if its not throwing any start asking around.
    DA SQUAD MEMBER #70
    91 da/95 gsr/boosted/awaits tune....
