Thread: Breaking up on high rpm shifts
    Norcross
    Default Breaking up on high rpm shifts
    car: 92 civic b16 swap
    When i get on the gas, sometimes it sputters or like hesitates after a high rpm shift. Sometimes after i shift n step on the gas the car doesnt even respond untill i let off the gas and press again. What could this be? i was thinking something with the dizzy, but i would like some expert advice reps for help
    hard to tell without looking at it myself.
    But I would check this
    plugs,wires,cap,rotor,fuel presure,coil (voltmeter test), is the dizzy tighten down not loose,etc best of luck
    Norcross
    Quote Originally Posted by Tech5 View Post
    thanks, will check today
    Johns Creek
    Definitely an ignition problem.
    All Motor BlackDubs's Avatar
    Atlanta,GA
    Quote Originally Posted by David88vert View Post
    IA's bass guy
    Nov 2009
    paulding
    id go wit jonbunklahom on this and check those but im not sure if civics has these or not but id check your cam sensors to cause my old eclipse sounded similar to that prob and it turned out to be that.
    Quote Originally Posted by imprtguy_94 View Post
    Nope they do not
    GWINNETT IS GREAT!
    dizzy
    change it
    if its not the problem, return it back to the parts store.
    my bet is on the dizzy tho
