Results 1 to 4 of 4
Thread: 03 stratus help
    the duckster
    Rome
    Default 03 stratus help
    so my mom drives a 03 stratus. for the past couple of weeks, the car has been jerking while acceleration. like it is hessitating. it is an auto but trans and motor oil is fine. the engine light has been on and so we hooked it up at advanced. it said cylinder 4 was misfiring. when we changed the plugs, there was some oil on the 4th plug. i was thinking piston rings?
    lmk guys
    Race Ready Developments Member #5
    Rome Crew
    Quote Originally Posted by ducky1177 View Post
    lmk guys
    tube seal
    change the spark plug install new valve cover gasket set with tube seals, but the oil isnt from the motor it got on the plug when you pulled it out. your plug wire should have little oil on it too.
    if the plug doesnt fix it, compression check and check the wires also
    best of luck
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    also the oil will cause a misire while grounding in the oil that leaked from the valve cover into the plug tube.
