Thread: will i pass emissions?
    Senior Member mccoy1178's Avatar
    Default will i pass emissions?
    k here is my ?,
    I got a 96 tegra shell and i have a full obd1 ls swap with engine harness. Can I pass emissions if i do the ckf trick since my obd1 ls motor doesnt have a crank angle sensor? Please help me so i can get my tegra running. thanx in advance!
    Mccoy
    2.2 CL
    if u can keep your light off and have a cat your good to go
    what ecu, need to be obd2 also, so it can read the port
    LAWRENCEVILLE
    If its the ckf i am thinking of then yes as long as you have a 0bd2 ecu no cels or pending codes and with a 96 you can have up to 2 montors not up and still pass.
    Hella stock member!
    yea im gonna run the obd2 ls ecu. thanx
    Certified Gearhead jojeezek's Avatar
    Jul 2009
    Quote Originally Posted by SLo_MKIII View Post
    If not then contact me.
    D16 + Turbo = The Replacement for Displacemnt
