Results 1 to 3 of 3
Thread: Custom 4AGE rods + hi-comp pistons
    Default Custom 4AGE rods + hi-comp pistons
    I have a set of bluetop rods with custom machining to bore out the rods journal to work with hi-comp pistons. If you have always wanted affordable high compression setup for your bluetop without buying the red-top crank and rods, then this is it. You get the lighter internals + high compression for the best combination. This is done professionally at a reputable machine shop (which cost me quite a bit). Hi-comp pistons are made by Clevite. Used for about 6000 miles before I installed GZE pistons to turbo. Rings will be included. There are some minor scoring on top of 1 piston, but should not affect anything.
    I want $100 for the rods and pistons + rings & pins.
    $50 more and I will include an excellent condition bluetop crankshaft that I used with those pistons. No scorings on journals either.
    Just dust on the far left journal
    more info on the pistons?
    i may be interested.
    OldSkool jdmjohn's Avatar
    got any gze pistons for sale?
