Thread: thermostat location on b20
    Gwinnett-Grayson
    Default thermostat location on b20
    my engine is just running cold so i im assumin the thermostat is stuck open, im going to replace it. but i need to know the location of it. is it on the exit hose of the radiator on the top of the block or the bottom hose?
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    West palm beach
    connected to the metal water line that runs under the intake manifold...
    Gwinnett-Grayson
    thought so. thanks, i just wanted to make sure.
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    At the end of the lower radiator hose, in between the intake manifold and the engine.
    My line of work
    www.internationaljets.com
    Columbus
    the bottom radiator hose where it connects to the block. this isn't the one for a b20, but its verry similar.
    remove the 3(i think) bolts and take it off. the therm is on the inside. just rem how it goes it.
    Gwinnett-Grayson
    thanks man i appreciate it, i jumped to a conclusion earlier today so i couldnt get to it. but ill get to it as soon as possible car is still runnin fine, just needs to get the thermostat replaced asap! i dont have to remove ALL thouse damn hoses though do i?
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    HI HATER!!!!
    norCross
    not at all just the hose running to it other people do but ive never had to
    i say the police
    06 sentra - toatolled
    91 integra ls- project underway
    West palm beach
    Quote Originally Posted by ctzfinest18 View Post
    wtf are you saying ?
    x2
    HI HATER!!!!
    norCross
    Quote Originally Posted by blacknightteg View Post
    for all those wondering
    i say the police
    for the record it helps if u quote that the first time around.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    just take the 2 10mm bolts out with hose on pull on hose and put in new thermo in and gasket then re assemble. and on some the ground may be on there and some are on back of housing. no need to remove hoses.
