Results 1 to 16 of 16
Thread: D15b/Z6?
    2.2 CL
    Default D15b/Z6?
    okay so i have a jdm d15b block but for some odd reason it doesnt have a vtec head on it. So im contemplating putting a y8 or z6 head on it. Since the block is already a vtec block what all would i need to do? i was thinking dizzy and obviously putting the head on there. anything else?
    (ノಠ益ಠ)ノ smoknlegend's Avatar
    Around
    Most likely it isnt a vtec engine. The jdm d15b non vtec is equivelant to a d15b7, and came with what looks like a vtec port but its for a mechanical fuel pump since the non vtecs often came as a dual carb unit.
    My reasoning? My hatch has a d15b non vtec in it.
    Sep 2008
    lithonia
    all y8 parts work with the d15b, so the usual stuff.
    Slimm
    South Side Georgia
    I think D15B are vtec. Weird
    resize pic
    Sep 2008
    lithonia
    Quote Originally Posted by smoknlegend View Post
    u just taught me something. my d15b is vtec.
    Slimm
    Around
    i correct myself, the jdm d15b came in both vtec and non vtec, the non vtec was prior to the 92-95 era.
    2.2 CL
    is there any way to tell? i have a block that reads "D15B" and a head code pm3-4 which is a d16a6 if im correct
    Around
    if your valve cover looks like this, the b8 vc, then its the non vtec version.
    Random photo off cardomain:
    And your head code is the same as mine, pm3-4.
    Quote Originally Posted by Wikipedia
    Found in :
    * 1988 Honda CRX 1.5X (rare)
    * 1990 Honda Civic 25XXT Formula (Japanese Market)
    * Honda Civic Ferio MX (Japanese Market)
    * 1998-2001 Honda Capa GA4 (Japanese Market)
    o Displacement : 1,493 cc (91.1 cu in)
    o Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
    o Compression : 9.2:1
    o Power : 106 hp (96.9 kW, 105 ps) @ 6500 rpm
    o Torque : 95.4 ft·lbf (13.2 kg/m) @ 4500 rpm
    o Rev limiter : 7400 rpm
    o Valvetrain : SOHC (4 valves per cylinder)
    o Fuel Control : Dual Carburetor
    And it can be converted for FI. Just put the FI intake and block the hole (which is for a lobe on the camshaft to operate the fuel pump on the Carbed version).
    2.2 CL
    ok cool thanks bro....
    AccuracyPerformanceAutomotive
    I had a 88 hatch with a d15b non vtec. Some of the usdm's had the d15b non vtecs also. But if you pull the oil restrictor out it becomes a vtec block.
    500whp of spinnin fury!!!
    Senior Member EJdm's Avatar
    i had a 95 civic ex with a jdm d15b vtec...i also threw a z6 head on it at one time too it ran just as good...
    the d15b vtec is a po8 i got one there nice vtec pops good and it has almost as much hp as ls motor
    Around
    Quote Originally Posted by QWK D16 View Post
    ooooo please do tell. You have my interest
    GWINNETT IS GREAT!
    damn that things like pushing 80 som hp to the wheels
    Random, not mine.
    This will allow vtec to work.
    This was mine. y8 head on a d15d non-vtec block....and turbo.
    Senior Member G.C's Avatar
    Forgot
    love boosted single cams.
    :idb:
