Thread: When Building Oil Pressure in the block...How?
    SwiperNoSwiping!!
    Default When Building Oil Pressure in the block...How?
    Wehn you first build an engine, i know about building the pressure up in the block before you even get to start it... But the question that i have is where should i install the sensor for my oil pressure gauge? I only ask this because on the VTEC heads, there is also a port there that can be used for verifying oil pressure, in addition to the one on the back of the block. So, i was wondering which hole would be better for monitoring things inside the motor?
    u remind me of a wigger !
    is it for a permanent gauge or a hand held.
    www.jjspec.com Macon, Ga
    The one in the back of the block is in a passage that feeds the engine's lube system. I would use that one. Make sure to spin the engine with the ignition diabled till you see some pressure on a new engine.
    SwiperNoSwiping!!
    Permanent
    Permanent
    Def in the back of the block then.
    SwiperNoSwiping!!
    OK, Thanks' Yall
    Quote Originally Posted by jjmastertech View Post
    1990 mazda rx7 TII
    Oct 2008
    brookhaven
    anything after the oilpump.
    i have mine on the oil filter pedistal. but... i have a different engine so i dont know.
