Thread: Viper 160XV Remote Starter/Keyless Entry Systems - $70!!
    Default Viper 160XV Remote Starter/Keyless Entry Systems - $70!!
    Guys, we have a blowout deal on the Viper 160XV system!!
    They are full remote starter and keyless entry.
    We only have 4 left!! Come get yours today!!
    The advantage of a remote car starter like Directed Electronics' Viper 16XV is evident every bitterly cold or steamy hot morning. The Viper 160XV has a host of advanced features, such as the ability to be programmed with a Bitwriter for ESP control, including GPS tracking through an upgraded telephone remote control.
    The 160VX is compatible with gasoline- and diesel-powered vehicles with manual and automatic transmissions. Like most other remote starters, it has a starter kill-switch that turns off the engine if any pedals are pressed or the transmission is shifted without the key in the ignition. You can program how long you want the engine to run, with settings of 12, 24, and 60 minutes (using Bitwriter, you can select any time between 0 and 60 minutes). The operating range of this remote starter is excellent, at up to a quarter of a mile away.
    The Viper 160XV comes with a pair of four-button remotes, and the buttons can be configured to your own personal requirements. Horn honk, car locater, remote panic, defroster activation, and parking light flash are just a few of the functions you can set up. Once you install the Viper 160XV remote car starter, you'll wonder how you ever got going without it.
    Features:
    *New miniature 4-button Remotes
    *Cool super-bright Blue Status LED
    *Smaller module with Viper badge
    *Turbo timer and optional rear
    defroster activation output.
    *Dedicated 1 button start
    *Parking light flash
    *+/- Doorlock Polarity Outputs
    *Comes with Two 4-button Remotes
    *5 Programmable channels
    *Valet switch
    *Horn Honk output
    *Remote Panic/Car Finder
    *Domelight Supervision output ready.
    *Failsafe Starter kill Built in, along with
    Remote Start Anti-grind (active/passive).
    *Viper quality, with Limited Lifetime Warranty!*Super High Frequency Receiver (SHF)
    *XCRS-4 relay H/D capacity satellite relay.
    *Automatic configuration of remote buttons.
    *All models are Clone-Safe Code Hopping
    *Diesel mode with dedicated glow plug input.
    *Complete engine monitoring: Voltage or Tach
    *Programmable run times: 12, 24 or 60 Min.
    (0-60 minutes with the Bitwriter tool).
    *Dedicated factory security control wires.
    *Viper GPS Tracking System: ESP serial port
    Attached Thumbnails Attached Thumbnails -viper-jpg   -dsc_0037-jpg
    350z
    do u do install?
    Yes, install will be $70. Some cars may require an immobilizer, but will need to know what car it is going on.
    350z
    i got 06 350z
    TOYOTA TACOMA!!!! 1990wade's Avatar
    BETWEEN MACON AND DUBLIN
    DAMN THATS AN AWESOME DEAL..
    I DRIVE A TRUCK THEREFORE MY DICK IS BIGGER THAN YOURS....
    Quote Originally Posted by budlite View Post
    i got 06 350z
    The 350Z has the Can Bus High Speed system, so the bypasses are a little more expensive.
    System - $70
    Install Labor - $70
    Door Lock Bypass - $35
    Starter Bypass - $50
