Results 1 to 18 of 18
Thread: Fs: 92 COUPE VLSD HIGH COMP. KA
    MADE IN JAPAN nisman's Avatar
    sticks-winder area
    Default Fs: 92 COUPE VLSD HIGH COMP. KA
    SOLD! THANKS!
    *COPIED CL ADD, SORRY FOR THE LAZINESS
    -1992 240SX S13 COUPE SE
    -5SPD CONVERTED
    -Z32 R200 VLSD WITH J30 5BOLT AXLES
    -11:1 COMPRESSION KA24DE WITH SOHC PISTONS
    -248/248 CAMS WITH DRILLED GEARS FOR REINDEXING. CURRENTLY INTAKE 5DEG ADVANCE FROM STOCK LOBE CENTERLINE, EXHAUST 5 DEG RETARDED
    -PORTED AND POLISHED INTAKE MANIFOLD AND HEAD WITH SMOG REMOVED
    -HEAD HAS FRESH VALVE JOB WITH NEW GUIDES AND SEALS
    -NEW TIMING SET, RINGS, ROD AND MAIN BEARINGS
    -NEW GENERIC STAINLESS HEADERS, NEW MEGAN 2.5" TESTPIPE/RESONATOR, OEM CAT BACK WITH NEW 2.5" MAGNAFLOW MUFFLER
    -Q45 FUEL PUMP
    -NEW PLUGS & WIRES
    -98 PATHFINDER MAF WITH K&N CONE
    -ALTIMA ELECTRIC FANS WITH OEM B12 TEMP SWITCH
    -NEW RADIATOR
    -16X7 KONIGS WITH GREAT YOKOHAMAS 205/55/16
    -HAS WORKING HEADS UP DISPLAY, BUT CLUSTER DISPLAY OFTEN NEEDS A BUMP TO WORK
    -SMOKES ON START UP AND HARD REVS BECAUSE OF CYLINDER WALL SCORING FROM PREVIOUS BLOWN HEADGASKET. PROBABLY SHOULD HAVE BORED IT OUT, BUT ALREADY HAD STD PISTONS AND RINGS. ALSO NOT HAVING A CAT MAKES IT LOOK WORSE THAN IF IT HAD ONE.
    -I THINK IT WOULD BENIFIT FROM A SAFC, LARGER INJECTORS (CAN INCLUDE USED 370'S), AND A TUNE. MAYBE A 2.5" EXHAUST. I JUST GOT A NEW JOB, AND HAVE NO MORE TIME TO MESS WITH IT.
    $3250
    *will consider partial trades but I need money right now
    BRAD 7O634O1O14
    MORE PICS: http://s437.photobucket.com/albums/q...nsentra/240sx/
    Stang Mod slostang's Avatar
    Southside
    sounds like a fun little car. GLWS!
    sticks-winder area
    please dont bash my thread, and i won't shit on your front porch.
    sticks-winder area
    thanks^ not directed at you.
    Certified Gearhead tack311's Avatar
    WINDER
    You suck at life and so does your car. Just not as much as I do though.
    You forgot to mention the most important to 240 peoples....
    Crackless dash!
    Car is fun and pretty quick and looks better in person.
    Good luck Brad
    sticks-winder area
    thanks tackalbox! holla
    sticks-winder area
    (dusty)
    Apr 2009
    Chesnee, SC
    High Compress? I wanna see a video of this BEAST.
    She Got It
    Stone Mountain
    Come up off that staquest in the garage
    southside
    looks like a FB to me,but i could be wrong..
    nice looking KA coupe.
    sticks-winder area
    ^thanks, its a fb.
    Sprayglo rep.
    G-nett
    pretty clean car and engine man
    WINDER
    Someone needs to buy this. This poor bastard has got 12 ninjas to support that sit around and do nothing all day except drink his Mountain Dew. Then when he gets home they're all hyper so they kick his ass because they are out of Mountain Dew. It's a vicious cycle.
    sticks-winder area
    and i don't know karate. ^gracias.
    sticks-winder area
    tack has 1 ninja but its like having a few alone.
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    VERY clean.....GLWS
    sticks-winder area
    thanks! feed the ninjas.
    sticks-winder area
    halloween bumpo
