Results 1 to 18 of 18
Thread: Confederate " P120 Fighter"
    Nissan Enthusiast
    Loganville
    Default Confederate " P120 Fighter"
    ENGINE: Radial twin / 120 cubic inches
    POWER: Rear wheel torque - 135 ft lbs | Rear wheel horse power - 160
    DIMENSIONS: Wheel Base: 64 inches; Seat Height: 27 inches; Rake: 30 degrees; Trail: 4 inche; Weight: 460 lbs; Fuel: 4 gallons; Oil: 4.5 quarts
    CHASSIS: CM design triple load path 6061 aircraft grade aluminum monocoque backbone, bulkhead, fuselage side plate construction; oil/fuel in frame
    SWINGARM: CM design 6061 aircraft grade aluminum
    FRONT END: CM design double wishbone machined from 6061 aircraft grade aluminum linked to aerodynamic dual lightweight tubular wing blades
    PRIMARY: CM design; machined from 6061 aircraft grade aluminum; belt drive
    TRANSMISSION: CM design vertical close ratio 5 speed
    SUSPENSION: Race tech; low/high speed compression and rebound adjustable
    BRAKES: Brembo high output race derived 4 piston technology; radial pumps; carbon, ceramic, aluminum matrix lightweight discs
    WHEELS: CM design carbon fiber; Front: 19” x 3” Rear: 18” x 8”
    GAUGES: Precision integrated analogue meter; warning, speed, RPM
    IDENTIFICATION: Limited edition; each example is one of 120; fuselage, bulkhead, engine VIN
    More pics and info at : www.confederate.com
    They make two other bikes as well.
    99 Infinti G20t w/ Primera Parts and a few other small things
    Macon
    I don't understand what you do with that.
    small handle bars
    Stockbridge foo
    x2
    Jason..
    That is freaking awesome. I'd buy 2 just to drive one til if fell apart and have another to get on after that. Love it.
    Garage-Sixgun
    Macon
    rolla rollin
    middle GA
    idk if id want to ride it way to much for me but cool as hell none the less
    fagNwagN h23bb2's Avatar
    that last pic makes it look like a high dchool shop class hack job....
    Faggin' Wagon & Queer Kar
    Killing it Since1982 bloodline's Avatar
    new york city
    that shit looks crazy
    riding low is like a religion
    WillAgreeForReps!!
    The Town of Lula
    Looks unfinished.
    Senior Member G.C's Avatar
    Forgot
    Quote Originally Posted by h23bb2 View Post
    Would like to see you make one then.
    :idb:
    Certified Gearhead tk4g94's Avatar
    Helen
    thats insane
    what he said!, now where to start!! lol
    Peek-a-boo mofucka what now?!
    This has no use at all
    Quote Originally Posted by GSRteg® View Post
    Thats the entire point.
    Half the cars on this site...or more have no functionality. The whole reason is not to have it, the reason is to say. "I want to make ......THIS!" and make it.
    Garage-Sixgun
    Sneaker Freak Repiks's Avatar
    Jun 2009
    Anything confederate makes is amazing.
    It's more of a piece of art than anything.
    03' Lightning w/ Bolt-Ons | KLR 650 | Duece.
    In the Fucking A
    Quote Originally Posted by Repiks View Post
    Art is only art if its sole reason for existence is to be art. That means it can't have another use.
    That is not art, that is someone who has to much time on their hands and a cnc machine. Just because you can make it out of billet doesn't mean you should.
    Give me a cafe racer any day.
    I fucked ©hris's mom
    Savannah
    460lbs.. wow.
