Results 1 to 27 of 27
Thread: Motor mount problem
    Duluth, GA
    Default Motor mount problem
    B20 in a 97 hatch. The drivers side mount bracket that comes up off the block comes up too high. The bolt on the actual mount doesn't go through the hole in the bracket at all, it just sits right under it. I used the bracket from a b16. Which mount/bracket am I supposed to have?
    pics of issue?
    Duluth, GA
    Quote Originally Posted by BTEC View Post
    pics of issue?
    I know. I know. I forgot.
    Duluth, GA
    This isn't my picture... but it might help explain.
    The bracket in side one when connected to the block with the block sitting correctly in the car is above the mount in side 2. about an inch too high. So I'm thinking the bracket in side one is wrong. Which ne do I need for it to work correctly?
    Southside Ridin HATCH
    Maybe you have the wrong T bracket..
    agree as long as u have a si rear t bone the side mount should work.
    ^ had this problem a few months ago on a friends Ek hatch.. we were trying to use the GSR T bracket... im 90% thats what it is..
    GL man
    Certified Gearhead 91boostdgsr's Avatar
    Jul 2009
    Griffin, GA
    have you tired an ls bracket maybe?
    INSERT SIG HERE>>>____________________________
    Duluth, GA
    I'm using all the same mounts that were on my b16
    dteng Homer Simpson's Avatar
    Evergreen Terrace
    you MIGHT have to us an SI "timing belt" bracket/mount?
    Cause I remembered when I did my GSR swap into my EJ chassis, I had to use SI tranny bracket and SI "timing belt" mount
    I'm not too familiar wit b20's, but I would assume its the same as a b18c
    Edit: nvm. You are using a b16 mount...
    Duluth, GA
    Any other suggestions?
    all stock mounts correct?
    remove both lower torque mounts
    if u have a si t bone, teg tranny mount, si driver bracket or crv there should be no problems.
    Duluth, GA
    These mounts all worked perfect with my 99 b16. When I first put the motor in I didn't have the A/C bracket mount on and the motor was sitting diagonal downwards towards the drivers side. When I put it on it lifted the drivers side mount bracket off the mount. All the other mounts are bolted down and the motor looks perect where it is. And my axles line up perfectly.
    so it was the torque mounts? cause i no understand what you just posted
    x2^
    Take the front lower driverside tq mount OFF..
    Duluth, GA
    x2^
    NO. You don't understand. With it off the motor sits leaning to a 45 degree angle towards the ground.
    Quote Originally Posted by Captain-Obvious™ View Post
    then you have a wrong mount somewhere. its either going to be the wrong driver side mount or wrong tranny mount... it cant be much else to be truthful.
    take the t bracket off. and try to use just the upper tranny and drivers mount, if it sits flat then you found your problem.
    it if it doesnt then you obviously found the other problem. ya dig?
    and post a picture of said problem nexttime... it speeds things up
    Duluth, GA
    Explain to me how these mounts worked for a b16 but not a b20. That's what I really need to know.
    maybe a b16 is shorter than a b20. i DONT know, thats why you try
    post a picture of each mount, maybe itll help
    im lost if u have all the right mounts there wouldnt be a problem.
    werd
    Duluth, GA
    All I know is the mounts worked with my b16. Because I drove it everyday. And looking at the way the mounts work with the b20 it is obvious to me that it will not work.
    well you just answered your own question. try to use LS integra upper tranny mount and LS block mount.
    all b20's ive done thats what ive used, i have never ran into a problem since
    LAWRENCEVILLE
    Bigger prybar!
    Hella stock member!
    If you are using all 99-00 mounts then there should be no problems...
    Are you using the Si engine mount (the one that sits inside the TB cover) and the one on the car side?
