Results 1 to 4 of 4
Thread: Trying to Find the correct ARP rod bolt part number...
    SwiperNoSwiping!!
    Default Trying to Find the correct ARP rod bolt part number...
    So far, after looking in ARP's catalog for connecting rod bolts, and looking on the JEG's website i've found two part numbers for ARP rod bolts and i'm wondering which one i should get, because they look to be almost the same with the exception that one is 8mm and one is 9mm. Which one should i get, if im trying to build an LS-vtec bottom end?
    ARP connecting rod bolt: Part no. 208-6001
    -Rod Bolt kit
    -1.2, 1.6, and 1.8L
    -8mm
    http://www.jegs.com/i/ARP/070/208-6001/10002/-1
    ARP connecting rod bolt: Part no. 208-6401
    -Rod Bolt kit
    -Honda/Acura 1.6 & 1.8L
    -9mm
    -Non-Wave Loc
    http://www.jegs.com/i/ARP/070/208-6401/10002/-1
    u remind me of a wigger !
    i believe 8mm are ls. wait for a confirmation from samebody else.
    SwiperNoSwiping!!
    okay... see, I just wasn't sure because I was slightly hoping that I could get some bolts that are more stout than stock, since it'll be a higher revving engine.. would it be possible to get the 9mm bolts and get the rod caps machined to fit?
    8mm arp will hold up to whatever. no need for anything else.
