Results 1 to 11 of 11
Thread: Anyone fix Xbox 360's?
    Aug 2009
    Cartersville
    Default Anyone fix Xbox 360's?
    My dad's 360 craped out on him with the good old fashion RROD and we need it fixed since this solution would probably be much cheaper than buying a new one. so if there is anyone who can fix it for cheap that would help
    R A W! x Resilience's Avatar
    Atl
    Check on craigslist, there are plenty of guys fixing them.
    You niggas know my pyroclastic flow, its R A W!
    - Current: E36
    DC5-R
    Gwinett
    you can fix it yourself, I've done 3 myself already. Go to youtube, and type in RROD fix, or E71, or whatever problems you have. Its simple, you can go to lowes and spend about $4 in screws, washers, plastic washers, and nuts. Then go to radio shack and pick up some thermal compound, artic is the one you need. Some cuetips, and a star-bit set is all you need.
    Quick breakdown.....
    Open up your xbox
    remove the "X" braces on the back of the heat syncs, use a small flat head to pop them out.
    Clean off the chips with rubbing alcohol using your cue tips
    clean off the back of the heat syncs
    Apply the new thermal compound that you bought from radio shack but be careful not to get them on the resistors. Apply a "dab" of the compound on the chip and back of the heat sync.
    Use the new screws and washers to attach the heat syncs back to the board, forgot the thread size and length but it should be on youtube.
    Turn on xbox and it should overheat, let it overheat for about 15-25min.
    Turn off the xbox and let it cool completely.
    After that you should be good to go
    And no this is not the towel method, that shit fucks up your xbox even more.
    Norcross
    my freind fixed mine for me. PM me if u want some info
    "Turn on xbox and it should overheat, let it overheat for about 15-25min."
    WTF is that? That sounds like a terrible idea...
    I mean, everything else in our post sounded like a good idea.
    Indecisive SOB aguynamedpat's Avatar
    In your attic
    Quote Originally Posted by IntegraXTR View Post
    Open up your xbox
    I tried this with mine, and it did not work. I had two with RROD.
    Quote Originally Posted by Psycho View Post
    I don't know any dentists, but I got a dremel and a handful of oxycontin. If you got $50 we can make this work.
    CCIE guinness's Avatar
    sugarloaf
    do you have your 360 on its side or on its bottom?putting it on its side will cause it to overheat and cause other problems.one of my friends is great at fixing these things.he's on my friends list on my profile.his name screen name is firesage2007 but his real name is ben.contact him and he should be able to really help you out.his life is game s and that is what he does above everything else.give him a shout.
    In your attic
    How much would he want to fix one? Or two?
    sugarloaf
    Quote Originally Posted by aguynamedpat View Post
    idk.he's actually a friend of my brother's,goes to collee with him,and all he does is play games,make games(burns),mods systems,and troubleshoots/repairs systems.ask him those kind of questions becausehe would have all those answers you are wanting.i don't know what his schedule,school and work,is,but still hit him up for any qiestions or concerns.i'm very confident that he would be able to help yous guys out.
    DC5-R
    Gwinett
    Quote Originally Posted by jorgen View Post
    the overheating part is important because it re-alligns the "solder points". Unless you feel like re-soldering your board.
    Sounds stupid? I've done 3, and still playing it now.
    In your attic
    Integra, PM sent.
