Thread: 4 wire o2??
    Senior Member DustnU's Avatar
    I'm on a boat!!
    Default 4 wire o2??
    Need to wire up a 4 wire O2 in place of the 1 wire cx. Have a p28 with vtec wired right already I hope now need to wire up the O2. Can anyone help??? And will this cause a fat spot when VTAKKKK kicks. Motor is a vx block and y8 head if that helps!!!
    Work in progressneed slicks!
    I'm on a boat!!
    Got it thanks!! Now will that cause the bog when vtec kicks????? and will that cause a sputter if not changed over???????
    lets put it like this the car doesnt know how much fuel to give.
    Oct 2009
    i had a problem with this too...hope u figure it out
    SwiperNoSwiping!!
    Quote Originally Posted by DustnU View Post
    It very well could also be that the vtec switchover point is too low. Because, i had mine set up and it used to bog when i went into vtec and then would pickup again after a little bit... I changed the vtec point, and it worked perfectly. ??
    u remind me of a wigger !
