Results 1 to 21 of 21
Thread: hey barefoot i hear you are a mechanical genius
    Certified Gearhead b20vtecrr's Avatar
    Jun 2009
    423 chatt
    Default hey barefoot i hear you are a mechanical genius
    i recently got a b16 skunk 2 intake mani. when its on the car and you look to the lower left theres a hole where radiator fluid comes out. ive got a radiator hose ran from it correctly but theres and extra flange attached to it....... ive given up tryin to figure out where it goes to so i ended up ditchin my overflow tank and rerouting that flange to be recycled back into the radiator.... i dunno if thats good or not but it keeps me from losing fluid=overheating...man if you could possibly tell me where that flange NEEDS to be routed or somethin i dont see a place under the throttle body or map sensor for it everything else is plugged in correctly... thanks -b20vtecrr-
    Southside Ridin HATCH
    Are you talking bout lines from your TB?
    Jun 2009
    423 chatt
    nah theres a line with a flange i guess its overflow attached to the skunk2 intake manifold i know where the big 1 goes but no idea about the little 1
    Jun 2009
    423 chatt
    sic 4dr btw you should get an si grille or black that 1 out hahah i love it though
    pix
    Southside
    I believe thats the coolant line that runs to the Throttle Body
    Jun 2009
    423 chatt
    man im sendn u 1 of the factory b16 mani but its got a blockoff it doesnt have that extra exit flange i guess is what you would call it
    Jun 2009
    423 chatt
    you think? ive got the important 1s plugd off and theres still that extra 1
    Quote Originally Posted by b20vtecrr View Post
    well if u all the oem locations hooked up. u should be good to go. post a pix anyways and lets make sure.
    Jun 2009
    423 chatt
    Southside
    Yea I bought Skunk2 intake mani for when I had a B16 and GSR and installed both
    Jun 2009
    423 chatt
    see thats the oem b16 intake manifold...on the skunk2 mani theres an extra small hole RIGHT beside that big hole for plumbing to be attached.. i just wanna be able to take that ghetto rig off there and hook my overflow tank back up
    Jun 2009
    423 chatt
    ok what ab the LITTLE tiny one on the right side back of the mani where does it go????? theres two plugs under the throttle body also..uggh theres just alotta shit thats probly wrong hahaha im surprised my car is runnin as smooth as it is
    Jun 2009
    423 chatt
    also the bigass one in the middle on the front..it sucks alot of air and ive got it plugd off bc if i dont my car idles at 3000 hahahahahahahha NOT GOOD
    Southside
    If memory serves me correctly the big one connects to the water pump tub by the thermostat housing and on some TB there a little cylinder underneath that coolant runs through.
    Southside
    but I do remember blocking 1 off, I believe it's on the thermostat housing, if your have the little one on there
    Quote Originally Posted by EJ1soSlo View Post
    ^ that is a old pic
    Jul 2009
    i have a skunk two for my ls and there is a extra small nipple that is used on a b20 i guess....... i put a rubber plug over it.....
    Jun 2009
    423 chatt
    cool thanks guyyss
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    i had a skunk 2 IM on my ls, and i had the same issue, i just plugged it as well, never had any trouble...
    98 Acura Integra LS-DD
    ??????????????????-project
