Results 1 to 14 of 14
Thread: ecu?
    Senior Member ej6kidd's Avatar
    dallas
    Default ecu?
    whats the best ecu to run on a b16 obd2
    \m/>_<\m/ dorin48's Avatar
    Canton
    Is the b16 obd2 and you have swapped it or is it still in an obd2 car? Your question is a little vague.
    Canton
    double post*
    dallas
    Quote Originally Posted by dorin48 View Post
    well im bout to drop it in my 98 four door with the 99 si harness so im tryin to see if i should run a p28 with jumper harness or if there is a better obd2 ecu to use
    Canton
    Do you live in an emissions controlled county?
    dallas
    yea thats another reason im askin as well lol sorry for the lack of info
    Canton
    One more question. Do you plan on needing serious dyno tuning?
    dallas
    na not really car is just a dd
    Canton
    Then def. use the obd2 b16 ecu.
    dallas
    ight kool so if i was to run a p28 that will mess up the emmisons
    Canton
    Quote Originally Posted by ej6kidd View Post
    There are ways to make the P28 work but why bother? A chipped p28 + jumper harness + basemap is no better than a stock obd2 b16 ecu in this case (and more expensive)
    dallas
    thanks for the help
    pmed i got ob2 si ecu
    Oct 2009
    i'll go with the obd2 since its going to be ur dd
