Thread: FS: AE86 parts
    OldSkool jdmjohn's Avatar
    Default FS: AE86 parts
    im cleaning up my garage. all these items are posted up on club4ag as well>>> http://forums.club4ag.com/zerothread?id=60748
    contact: [email protected]
    rwd 4age intake manifold w/ throttle body/tps/cold start injector (some dude thought it was cool to paint it silver..FTL).... $60
    fwd 4age intake manifold w/ cold start....$25
    usdm 4age ecu w/ oem mounting brackets (came off my 85 gts hatch)...$40
    in this picture below...$10 each
    grey under colum panels...$15
    grey passenger side speaker panel/bracket...$10
    black colum cover (off adj colum/ non cruise control)...$10
    grey stereo bezel...$10
    cam cover back plates...$10 each
    rwd 4age timing belt cover (bottom/mid section only) both: $10
    everything you need to convert your fwd to rwd coolant parts:
    -good/used condition water pump...$20
    -water pump back plate (w/thermo housing)...$40
    -hard lines...$20
    -upper radiator spout w/ all sensor and bypass tube...$25
    -rear heater core spout ***vsv are broken...$15
    turn signal assy...$10
    headlight/wiper switches... both for $10
    rwd 4age egr assy...$30
    oem shifter/boot and razo shift knob...$30
    fwd 4age waterpump/housing...$20
    fwd 4age waterpump pulley...$15
    rwd 4age waterpump pulley...$25
    (left) mr2 4age alternator...$35
    (right) rwd 4age alternator...$35
    ***both will work on rwd 4age bracket
    rwd 4age ignitor/coil...$25
    rwd 4age oil cooler/adaptor plate (oil lines not included)
    ***adaptor not in pic and it will be included...$40
    rwd alternator bracket...$30
    rwd power steering bracket...$15
    rwd t50 tranny mount/bracket...$20
    rwd 4age block to tranny brackets...$15
    rwd driver side/passenger side engine mount/brackets...both $40
    85 gts a/c evaporator (don't know if it works, but it held freon)...$10
    mr2 distributor good working condition (leaks oil/ needs rebuild) $15
    two sets of mudflaps...$40 each set
    zenki rear quarter panels...$45 for the set
    rwd gts 4age tranny bell housing...$100
    maroon gts dash (tiny crack) barely see it...$100
    iTrack matthewAPM's Avatar
    Otto-Flimm-Straße, Nürburg
    ive got a 4age redtop if u wanna buy it
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    Quote Originally Posted by matthewAPM View Post
    thanks, but i have many complete 4age longblocks laying around my garage. thats the next thing up for sale as soon as i clear out some room.
    brand noobian
    wherever the hell I want!!
    Do you have an ITB set? If so how much?
    Quote Originally Posted by Rol-N-GUy View Post
    i can get them. email me>>> [email protected]
    IA Member thecuborican's Avatar
    Aug 2009
    Quote Originally Posted by jdmjohn View Post
    I am interested in buying a redtop hi comp...got any? also ITB setup if you have that laying around. let me know
    404-275-4192 call/text
    I really need a running condition 4age longblock. How much would you want for one?
