Results 1 to 13 of 13
Thread: high compression pistons???
    2.2 CL
    Default high compression pistons???
    so im going to replace the piston rings in my car and was wondering should i throw high compression pistons while im at it (12:5:1) would it give me any hp gains on a stock ls? would it hurt my motor in anyway? i dont have a ton of money to start doing springs retainers rods etc...
    AccuracyPerformanceAutomotive
    I wouldnt go 12.5:1. A little high for pump gas and not tuning it. But you could mill the head slightly or get a thinner head gasket and get it in the 10 to 11 range. Much easier.... and cheaper.
    500whp of spinnin fury!!!
    2.2 CL
    Quote Originally Posted by QWK D16 View Post
    would there be any gains? better yet would it be worth the money invested?
    Piston money > headwork money.
    Certified Gearhead jojeezek's Avatar
    Jul 2009
    Tell me about it....$$$$ I know!!!
    D16 + Turbo = The Replacement for Displacemnt
    rolla rollin
    middle GA
    id go with the head gettin milled
    \m/>_<\m/ dorin48's Avatar
    Canton
    More compression = power
    How much? idk.
    Premium only btw one you crest into the 10:1+ range.
    2.2 CL
    Quote Originally Posted by dorin48 View Post
    How much? idk.
    only run premium anyways
    id go with the pistons no that high of a comp. i wouldnt mill the head unless it warped. milling is a 1 way process. so if u dont like u have to but a new head.
    Just raising the compression alone won't yield much hp increase. Save your money, and put it toward a nice valve job or even a port job on the head.
    you will see gains, but you'll need to tune it. otherwise, lean and detonation will occur on a stock fuel and timing map.
    Quote Originally Posted by scttydb411 View Post
    x2 Tune it.
    Senior Member goi_ek's Avatar
    zone 3
    well if u go through with it keep us posted, i might be interested in doing this too
