Results 1 to 30 of 30
Thread: The only way to travel in the desert..
    The Green Jeep STI101's Avatar
    Dunwoody
    Default The only way to travel in the desert..
    I want this thing just in case zombies take over
    Here are the specs
    Chassis
    * MAN TGA 6x6
    * Extended cab with 2 seats + 2 jump seats / bed
    * Wheel base 4500 + 1450 mm (14´9´´ + 4´9´´)
    * Engine erformance 353 kW/480 hp Euro 3
    * ZF 16-speed manual transmission
    * All wheel drive with center differential lock
    * Differential locks for front and rear axles
    * Parabolic leaf suspension
    * Tires 16.00 R 20 Michelin XZL, tubeless
    * Tire pressure regulating system
    * 2 chamber fuel tanks, capacity 750 liters (198 U.S. gallons)
    * Fuel prefilter with water seperator
    * Car alarm system
    * 2 air suspended seats and 2 jump seats, convertible to bed
    * Satellite navigation system (GPS)
    * Back eye camera
    * Integrated airconditioner
    * Roof rack with branch guard
    * Rack for 2 spare wheels, mounted at the rear
    * Searchlights left and right
    * Truck horns
    * Xenon high beam lights
    Body Unit
    * Frame assembly 3 point kinematic attachment with main and flex mounts for stress free body coupling
    to the torsion elastic chassis frame
    Body unit construction
    * Self supporting UNICAT sandwich plate panels of fibre glass composite
    * Panel connections made by adhesive bond to custom extrusions eliminates metalic
    heat conduction paths
    * Matched thermal coeficients of expansion prevent distortion with changes in temperature
    * Wall thickness 60 mm (2,36´´) with polyurethane foam insulation, 3 mm (0,12´´) FRP
    outer surface, 2 mm (0,08´´) FRP inner surface
    * Ins. rating 0,44 W/m2 K (0,078 btu/ft h degF)
    * Bottem panel with integrated welded steel frame and surfaces of FRP
    Access to drivers cab
    * Highly flexible waterproof bellows coupling
    * Sliding door to close passage way
    Entrance door and storage compartment doors
    * UNICAT - entrance door and storage doors constructed of fibreglass composite
    plates and frames
    * Thickness of doors 60 mm (2,36´´)
    * Double sealed doors with heavy duty locks with seal compression
    * Stainless steel hinges throughout
    * Additional retractable bolts at top and bottom of entrance door
    * Safety cylinder locks all keyed alike
    Windows and skylights
    * Burglarproof, scratchproof top hinged sidelights
    * Double insulated thermal window glass
    * Shutters and moskito nets
    * Windows and hatches electric powered
    Lifting roof
    * UNICAT - lifting roof with electric drive mechanism
    * Well insulated, expedition proven and maintenance free
    * Electric powered sliding roof above the bed area
    Interior Lay Out
    * Inner dimensions of the cabin length 6880 mm ( 22´7´´), width 2360 mm ( 7´9´´), height 2020 mm ( 6´7´´)
    Seating Unit
    * U-shaped seating unit with swivelling table on pedastel in the rear of the cabin
    * Seating unit converts to additional double bed
    Beds
    * Double bed with comfortable matresses in lifting roof area 180 x 200cm (5´11´´ x 6´7´´)
    Sanitary room
    * Separate shower and toilet room with doors, to seperate from livingroom
    * Washstand with lavabo
    * Hanger cupboard with mirror
    * Also usable as drystorage due to it`s own radiators
    Kitchen
    * Kitchen countertop with integrated sink
    * Single handle faucet for warm and cold water
    * Soap dispenser
    * 3-flame stove
    * Conventional oven with steamer
    * Dishwasher
    * Espresso maker
    * 2 x 120 l (26 gallons) fridge with ***-freezer
    * Kitchen closet with drawers
    Storage
    * Storage space in the seating benches with drawers
    * 3 big wardrobes
    * Large outside storage compartments
    * Aluminium exterior storage boxes
    Workmanship
    * All furniture is custom built to the highest cabinetmaking standard out of wood core
    plywood using heavy duty locks and hinges
    * Materials and finishes may be specified by customer
    Lay out
    * Design and color of floor, walls and ceiling may be chosen by the customer
    * Walls and ceiling are painted with multiple coats
    * Upholstery made of fabric, leather or ALCANTARA
    Technical equipment
    * Electrical equipment Custom control panel to control powermanagement and liquide storages
    * Battery main switch, savety cutout, fault current breaker
    * DC power supply by AGM battery bank, automatic I-U regulated alternator and AC
    automatic I-U shore charger with cell temperature sensing
    * Battery capacity: 24 V 765 Ah
    * Alternator charge rate: 28 V 110 A
    * Shore charge rate: 28V 100 A
    * Inverter 24 V/230 V, max output 6 kW
    * International shore power connectors 90 -260 V AC (45 Hz-65 Hz)
    * Power plugs for 12 V DC, 24 V and 230 V AC
    * Solar system
    Generator
    * Watercooled Fischer-Panda diesel generator with 2-cylinder diesel engine
    * Performance: 7,2 kW
    * Water cooled muffler
    Musik system / TV / Video
    * Music installation with CD-changer
    * Sound system
    * DVD player
    * TV satellite receiver
    Lighting
    * Integrated low voltage XELOGEN lights over the table, kitchen, hall way, shower,
    storage area and lifting roof
    * Lights for outside storage compartments
    * Reading lights in bed and seating area
    Water supply
    * 670 l (177 gallons) freeze proof drinking water tanks
    * 40 l (8.8 gallons) hot water-heat exchanger
    * Freeze proof waste water tank, capacity 220 Liters (52 U.S. gallons)
    * Water faucets in both bath and kitchen have removable sprayers
    * All components are built due to highest household quality standards
    * All plumbing is insulated to prevent freezing
    * City water connector and outside shower
    * Water filtration system
    LPG supply
    * 2 x 11 kg gas bottles
    * Remote controled management with gas alarm system
    Toilet
    * Porcelain-vacuum toilet with water flushing
    * Freeze proof sewage holding tank
    Heating system
    * Diesel/electric powered warm water central heating (18 kW) with engine preheating
    system and drivers cab preheating system
    * High radiant heat share due to radiators in living area and towel radiator in bath
    and shower area
    * Antifrost system
    Others
    * Integrated airconditioner, performance 5 kW (17,000 btu), powered by the generator
    or shore power
    * Central locking for all furniture
    * Safe
    * Integrated storage compartment for ATV in the back
    Weights and measures
    * GVWR 20.900 kg (46064 lbs)
    Overall dimensions
    * length 9513 mm ( 31´3´´), width 2480 mm ( 8´1"), height 3990 mm ( 13´1´´)
    * Additional length of spare wheel rack: 500 mm (1´6´´)
    Attached Thumbnails Attached Thumbnails -ex70hdq-mantga6x6-3-560-jpg   -ex70hdq-mantga6x6-4-560-jpg   -ex70hdq-mantga6x6-5-560-jpg   -ex70hdq-mantga6x6-8-560-jpg
    Dunwoody
    more
    Attached Thumbnails Attached Thumbnails -ex70hdq-mantga6x6-12-560-jpg   -ex70hdq-mantga6x6-13-560-jpg   -ex70hdq-mantga6x6-14-560-jpg   -ex70hdq-mantga6x6-15-560-jpg   -ex70hdq-mantga6x6-16-560-jpg
    earth ????
    hell yea i want shotgun !
    Dunwoody
    moo moo
    Attached Thumbnails Attached Thumbnails -ex70hdq-mantga6x6-18-560-jpg   -ex70hdq-mantga6x6-19-560-jpg   -ex70hdq-mantga6x6-20-560-jpg   -ex70hdq-mantga6x6-21-560-jpg   -ex70hdq-mantga6x6-22-560-jpg
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    NO SHIT!!!!
    I WANT 2!!!!!!!!!
    Dunwoody
    moooorah
    Attached Thumbnails Attached Thumbnails -ex70hdq-mantga6x6-23-560-jpg   -ex70hdq-mantga6x6-24-560-jpg   -ex70hdq-mantga6x6-25-560-jpg   -ex70hdq-mantga6x6-30-560-jpg   -ex70hdq-mantga6x6-33-560-jpg
    Chattanooga,TN
    whats that thing cost?
    Dunwoody
    a few more
    Attached Thumbnails Attached Thumbnails -ex70hdq-mantga6x6-35-560-jpg   -ex70hdq-mantga6x6-36-560-jpg   -ex70hdq-mantga6x6-karawane-560-jpg
    Dunwoody
    So badass
    Hates streched tires DunDunSkeert's Avatar
    Misawa, Aomori, Japan
    Freaking awesome! It's missing gun turrets though...
    I want one.
    Macon
    At first I was like
    And then I
    Senior Member G.C's Avatar
    Forgot
    lol you guys like the most random stuff. What's so great about that? a dumptruck.
    Mind as well get a camping truck if your going to get that. looks way better.
    :idb:
    GWINNETT IS GREAT!
    that thing is sick!
    Daytona Beach
    2 Things.
    1. These are used on the Dakar as reconnaissance vehicles and in the event as supply transport.
    2. Why do you make multiple posts for your threads? Wouldn't be easier to make 1?
    statesboro
    Damn the inside is cool as hell.
    Dayum didnt see that coming
    Go Skateboard. ItsBlack's Avatar
    that thing wont tip? It looks too tall, but not very wide
    1BA_BA4 89preludesi's Avatar
    Sep 2008
    i thought the inside was going to look like shit ..... but damn its so nice i want one
    Quote Originally Posted by G.C View Post
    Are you serious? Tell you what, you get a Coleman camper and i'll take that thing. When you are dead on the road i'll call your folks.
    It's built for purpose. Read the specs on it. Wall thickness, insulation. No Airstream is going to take care of you in the desert like that thing will.
    Garage-Sixgun
    f-ckouttahere. PRO®'s Avatar
    At first I was like
    And then I
    my sentiments exactly, lol
    ATH GA. SRCRX's Avatar
    On the drum set!!
    pimp'n!!
    Senior Member antiv6's Avatar
    g-nett
    i did not expect the inside to be so damn awesome lol
    Daytona Beach
    You just don't know enough.
    That is why you are confused.
    Warner robins ,Ga
    how big is the gas tank?
    WTF
    Dunwoody
    2 Things.
    Yea it would be easier to make one post, but I dont know how lol.
    in da clouds
    zzzzzzzzzzzzzzzaaaaaaaaaaaaaaaaaaaaaaammmmmmmmmmmm mmmmmmmmmmmmm that would be fun to ride in
    Bunny Colvin's Hamsterdam
    Just be sure to secure all those plates and bowls of fruit and stuff before you go offroading.
    Dunwoody
    When the Zombies come for your brains you will wish you had one of these instead of a camper.
    Dunwoody
    At first I was like
    And then I
