Results 1 to 22 of 22
Thread: launch control using chrome
    Jul 2009
    Default launch control using chrome
    hey
    im ordering my chipped ecu and have a question for you guys
    is 3500 rpms a little low for the initial launch control setup
    i know this is a stupid question but im wondering what yall usually use. ill be on street tires with my lsd equipped ls tranny
    also what kinda info do i need to send him for my base map anything suggestions at all are appreciated as i know nothing of chrome.
    ls/vtak slut! SlamminCRX's Avatar
    Hinesville/Savannah, GA, Orlando, Florida
    wat kinda power you making? 3500 should be ok. i wouldve set it at 4
    everywhere & nowhere
    Set it around 500rpms above where you make peak torque for starters. Then adjust according to bog - grip - vehicle weight - gear ratio etc. or leave it off like me and learn how to drive.
    roberta
    3500 should be fine thats what i plan on setting mine at
    your moms house
    3500 is ok for the street but will kill you at the track for sure you will bog everytime
    SwiperNoSwiping!!
    Quote Originally Posted by all-mota View Post
    Where would it need to be for the track? at the peak of the torque curve as mentioned before, or somewhere else on the powerband??
    u remind me of a wigger !
    ^^ depends on the tire - tire pressure - vehicle weight - rear spring - etc.
    It's not just a "magic" rpm. Any1 who tells you different is a dork. Trial and error my friend.
    Jul 2009
    thanks guys
    Wirkz
    mine is at 4. you should be fine with 3500
    UN!QU3 CR3@T!0N$ JP - In memory of John
    B-Town Crunk Force
    Statesboro, GA
    Mine is also set at 4 I believe. boosted ls with no lsd. Its perfect for the track. Overkill on the streets though.lol
    aye bro .:Stirfry:.'s Avatar
    mine was set at 6500 w/ a t25 on a b18,
    IMO go higher..
    ATL DAsquad Member #9
    Southside Ridin HATCH
    I wouldnt even get launch control set at ONE point.. If you are worried about it that much save for a program were YOU could change it whenever you want according to conditions...
    As stated before your 3k launch WILL suffic at the track.. or if you have DR it will also suffer...just different variables in the "correct" launch
    IMO just dont get it.. and LEARN how to launch your car in your different situations...
    B-Town Crunk Force
    Statesboro, GA
    But considering this is the FI section, Im assuming hes boosted.lol
    Launch control allows you to build up a few pounds of boost before you actually launch, which you cant really effectively do without 2-step.
    ^^^ If you can control the throttle w/ your foot (it's called driving) then you can launch a boosted car on the street on a few pounds. Don't spread misinformation.
    Furthermore... the 2-step just allows for measureable (repeatable) consistency at the track. Road conditions vary too much to use a 2 step on the street effectively. Even the aspahalt make-up from road to road changes.
    Like it's been said - learn to drive the car and you won't have to worry about a 2-step on the street.
    B-Town Crunk Force
    Statesboro, GA
    Quote Originally Posted by BABY J View Post
    No one is spreading misinformation.
    If you have a boosted car and youre about to launch it from a standing position, you can hold the throttle at a steady 4k, but you wouldnt build boost like you would if it was being held at 4K with 2 step. Thats all Im saying.
    And yea, to get around this, you could just launch at a higher rpm to make up for the lack of boost when launching. Or you could also give it wot and start to launch whenever you reach the rpm/boost level which the conditions call for.
    But either way, 2 step is the most effecient way to launch a boosted car IMO.
    if it's tuned on the gold software then you can have it set for wot launch rpm, or if you need to launch at a higher rpm (such as changing to dr or slicks) then you can feather the gas to launch at a higher rpm. it won't have the anti-lag/boost build while feathering, but it can always be changed.
    Jul 2009
    hey scotty... i ordered my ecu off ebay....
    its chipped with a zif and a 4 point datalog plug.....
    its got a basemap but i think ill be getting you to do the tune when im done fabin up my turbo kit.
    im waitin on a 0bd1 dizzy, dizzy adapter, and obd2 to obd1 harness converter.
    Jul 2009
    can you do high boost and low boost mapping with a setup like mine or do i need the dual chip thing that has a little switch guy....
    im just trying to do the most work i can to keep costs down
    Certified Gearhead 91boostdgsr's Avatar
    Jul 2009
    Griffin, GA
    ive got mine set at 4000 rpm and it launches hard
    INSERT SIG HERE>>>____________________________
    Quote Originally Posted by dallasb84 View Post
    you should still be able to run the obd2 dizzy and not need a dizzy conversion. just get the obd2-1 ecu conversion harness from www.boomslang.us
    you can typically do all the tuning on the same map unless you want 2 different tunes for pure pump gas and pure race gas. if you're running a profec b spec2 or other ebc i'll tune it on wastegate, lo boost the highest we see fit for pump gas and then highboost reserved for a race gas 20+psi tune if you want to go that route. if you're not going to go that route then high boost the highest on pump and then lo boost somewhere between wastegate and hi boost. typically on same chip.
