Results 1 to 28 of 28
Thread: So i tried to remove one of the bolts from my valve cover...
    '99 EK Hatch
    Sep 2009
    Acworth
    Default So i tried to remove one of the bolts from my valve cover...
    and this happened. Am I fucked? Any suggestions for what to do?
    The bolt seems to have broken off in the hole.
    I have a D16y7 in a 99 EK Hatch
    Is there some sort of fix I can do to keep the car running another few 1000 miles, or do I need to get a new head/valve cover?
    WTB EK hatch cargo cover. $50
    Looks like the stud broke off in the head. It's repairable. Either snatch it out or drill it out and put in a new insert if there is space. Never had a insert in the motor though. If it runs ok for now, put a rag in the hole to keep debry at bay. And repair when you get a moment.
    You may be able to get it out. Probably salvageable.
    '99 EK Hatch
    Sep 2009
    Acworth
    I haven't even attempted to crank the engine. I was thinking of trying to plug the hole so i can drive it to a shop.
    Bolt the rest up, put the broken one in the hole and drive her up.
    '99 EK Hatch
    Sep 2009
    Acworth
    the fact that its loose wont present a problem? I will probably bring it to you guys at mainstream.
    It will leak some oil, but as long as you do not have to drive too far, it would be ok.
    '99 EK Hatch
    Sep 2009
    Acworth
    alright, ill bring it to you guys at mainstream tomorrow to get it fixed. any idea how much it would cost me to fix it?
    columbus GA
    i broke a bolt on my fuel rail like that but yours is down in there so im not sure if you can get to it take a dremel tool and make a line across the bolt and just unscrew with a flathead screw driver.
    The REAL Scrapy :)
    Oct 2008
    If the bolt snapped, then it probably wont loosen with a screwdriver.
    1990 Eclipse GSX - 13.0@ 108 on old setup
    1990 Eclipse GSX - "The Whore" Shell being built
    2001 Dodge Dakota - The pizza delivery-mobile
    '99 EK Hatch
    Sep 2009
    Acworth
    I plan to take it to mainstream tomorrow after school to get it fixed, plus, I dont own a dremel tool
    columbus GA
    it could have snapped because just the top was twisting and broke off but if the bolt is shorter it wont be under as much torque or stress whatever you wanna call it and it should come out
    mr.slow
    lawrenceville
    daimn dude i went through the same thing lol
    so i just replaced the whole head...
    '99 EK Hatch
    Sep 2009
    Acworth
    cant afford to replace whole head right now. I have $900 and have to pay a $300 ticket plus insurance. No job either.
    edit:if I could afford to replace head, I would go with a minime swap
    i broke mine putting it back on..i just put it back on and put silicon around it..been fine for a year..ha hacked up but o well..
    '99 EK Hatch
    Sep 2009
    Acworth
    lol the silicone keeps it from leaking?
    EXTRACT IT
    lawrenceville
    dude thats a do it your selfer Pep Boys sell a Bolt extractor tool for that size bolt its long square little rod with sharp edges at the end, you grabbed a drill bit about the sized of the bolt and drill a hole at the very center of the broken bolt inside the head, becarefull doing this part cause the drill bit tends to slip of the side. after you achieve the hole in the bolt you grab the extractor tool insert the sharp end on the hole you made and the you tap it with a hammer get good and tight then twist away
    if you cant do it PM ME and ill do it for a small fee... ofcourse
    FYCN in a rick james voice
    Delete me please
    Apr 2009
    Delete me please
    Delete this profile please
    Jul 2009
    get an easy out
    and a new stud
    mayeb a 15 dollor fix max
    lol im with the diy guys its a simple 10-15 fix with a autozone home depot whatever bit extractor.
    '99 EK Hatch
    Sep 2009
    Acworth
    well man, I would probably screw it up if I tried it myself.
    Quote Originally Posted by MikeDubs View Post
    if thats the case. if i was u i would never touch another car for the rest of your life. or anything else that might have some assembly required.
    '99 EK Hatch
    Sep 2009
    Acworth
    im gonna take it to mainstream today and get it fixed. it runs without leaking much oil. I should be able to get it over there without screwing it up majorly
    the world needs more people like yah. lolololol
    yea man its like the fuckin easiest fix youll have to do yourself ive seen this happen alot on peoples cars its not that serious at least it wasnt a head stud
    Sep 2003
    Been there, done that, used a screw driver to twist it out! Luckily mine was loose! Easy outs are fun, just dont break that joker off in there! Then you truly are screwed (for the most part)!
    '99 EK Hatch
    Sep 2009
    Acworth
    James at Mainstream fixed it for me. Thanks man. +reps
