Well I have a 1990 ef hatch I got it and someone had started a wire tuck already.I havent checked any of there wires they did for the lights at all.But I have two codes one is 20 and the other is 6.I dont know why I have either codes only thing I can think of would be, When I did the injectors for multiport it says solder the yellow and black thick wire together with some other wires/wire. But all the connections I did were straight I soldered them correctly.But I dont think its the Engine harness I think its the wires they did for the lights because some are loss.Car also has obd1 conversion also with o2 and other wires but they are all closed and taped.My friend told me it is along the lines of alternator wiring.Well I think it might be the alternator because I had same stuff in another hatch and had same code.Lmk what you guys think.Reps for good info
.So im just straight confused no im not using a obd0 block the block is from a obd1 car.All of my grounds are correct only thing I can think of is Eld.Because my black hatch ran but once I put the motor back in and it threw ELD it wouldnt start.
