Results 1 to 19 of 19
Thread: Car will not run unless I hold the gas.
    C.r.E.a.M MistaCee's Avatar
    Work
    Default Car will not run unless I hold the gas.
    I have a 1998 vw gti that just started acting up on me. I believe it the idle control valve but I want to get second opinions. When I start it in order to keep it running I have to quickly give it gas as soon as I take my foot off the car completely stalls. Any other thing that can be the problem other than the icv?
    any recent work done or codes.
    Work
    No I havent touched anything at all.
    Southside Ridin HATCH
    soo no codes?
    Had to replace the throttle body(icv inside tb also) of VW a while back. It Had the same problem.
    can you drive it? and it just goes duper slow?
    Work
    Im sorry yea no codes. It doesnt drive slower that I know of I havent really taken it out since it started but from the little driving it has done since then I don't see a difference apart from not holding the idle. Ima pull apart the TB and clean out the ICV
    too low of idle maybe?
    i dont work on anything german but ill throw out some ideas
    iacv
    fuel pump
    egr
    pcv
    vac lines
    clogged injectors
    ^ yea check the vac line coming from the VC
    Work
    Ok im gonna have to check those out tomorrows thanks.
    If you need any assistance let us know. We can take a look at it for you.
    Zen Motors LLC
    Local Phone:770.904.2868
    E-Mail: [email protected]
    Website:www.ZenMotorsLLC.com
    Unknown
    Dun dun dun dun dun dun dun dun dun dun dun dunnnnnnnn....... lol......................yo HAVE YOU REPLACED THE "FUEL FILTER" YEAH YAH replace the fuel filter.....:-)
    It's located in front of the passenger rear wheel...under some plastic shat...Under the car...
    AccuracyPerformanceAutomotive
    ^---- wat wat wat wat....lol....wat????--^
    Prolly the iacv is bad if no vac lines are off.
    500whp of spinnin fury!!!
    is it sputtering while you drive?
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    Work
    I found out problem had a faulty vac line. Running minty again.
    woot #5 on my list of random guesses.
    Work
    Haha yup and the first thing I check being it was most simple Thanks man huge props.
    Joo is ghey
    Duluth, GA
    unplug the maf, see if your car will idle better. if the problem is gone, then change your maf.
    Quote Originally Posted by cdhtang View Post
    your a lil to late with the incorrect info. he has it figured out.
