Results 1 to 17 of 17
Thread: B18B1 EG
    fuck it thug it JdM_EJ2's Avatar
    the streets where we burn sweets,Gwinnett county hoe
    Default B18B1 EG
    JUST DROPED IN A LS IN A EG AND ITS HEATIN UP ALL THE WATER/ANTIFREEZE AND IT OVERHEATS AS SOON AS I PULL OVER AND ADD ANITFREEZE IS PULLIN GOOD UNTIL IT HEATS THE WATER...ALL HOSES ARE GOOD THERS NO LEAKS THAT I CAN SEE THERMOSTAT IS WORKIN SO I HAVE NO IDEA WHY ITS MESSIN UP...COULD IT BE THE RADIATOR? PRECIATE IT ANY INFO YALL GOT
    is it boiling out the over flow tank.
    IT BOILS IT INSIDE THE TANK AND ITS GONE BY THE TIME I PULL OVER I HAVE TO ADD WATER TO IT AND TO THE RADIATOR
    Norcross
    is the car smoking?
    the boiling gone or the tank is empty with steam coming from the it.
    NAH THE CAR AINT SMOKIN AND ITS GONE WITH STEAM COMING OUT THATS WHEN I PULL OVER AFTER IT OVERHEATED BUT BEFORE THE NEEDLE GETS THE RED AND U GO LOOK AT IT THE WATER IN THE TANK IS CHILLIN THERE BOILING UP
    i need this again in english and no caps
    No the car does not smoke.The water in the tank in gone by the time the temperature needle is in the red and i have pulled over to add water/antifreeze.If the temp needle has not reached the red and is very close to it the water in the tank is boiling but is still there
    is that english enough?
    Quote Originally Posted by JdM_EJ2 View Post
    thank u all u had to say from the get go. keep adding fluid bleed the lines. your system isnt full yet so it keeps sucking in all the fluid. if it was blowing all the coolant out it would be the head gasket.
    alrite ima try that
    also check if you radiator cap is bad.
    maybe your headgasket was installed wrong?
    or you got a leak somewhere
    Jul 2009
    +1 radiator cap
    thanks for all the input found out what the problem was...the hose that goes from the head to the lower part of the throttle body had a small rip and would leak the water thru there
    i bet u want to take that statement back.
    nope not really...i did this for a friend so i just wrote whatever he said
    Senior Member EJdm's Avatar
    this is whats going on with my shit to...i gotta check it out tomorrow after work if it doesnt rain...
