Results 1 to 14 of 14
Thread: how do you?
    slingshot sales ceo. ls-r teg's Avatar
    gwinnett
    Default how do you?
    i have a obd2 honda with a obd1 jumper harness and ecu....i have a hard cel....how do i find out what it is?
    STILLHAVE THAT PENIS ?????
    They should have never gave u niggggas vtec
    might be the ecu, tried a different one?
    Quote Originally Posted by ls-r teg View Post
    explain
    Southside Ridin HATCH
    He cant read the codes by "CEL reader" cuz of the ecu/harness, so he is asking which TWO pins to connect to do that trick..
    The blinking cel code trick..
    Correct??
    or he did it, it stay on and hes trying to find out why
    How ever many times the light blinks as in 4 blinks , then 3 blinks...= code yata yata 43
    actually if he was to read like how you say, it would be code 7 lol
    if he read 4 long flashes and then 3 quick ones, THEN it would be 43
    ^ Yea thats what i was tryna say ...
    Thanks.. lol
    gwinnett
    i thought u could only do the blink trick for obd1?? im saying like as soon as i put the key in the on position the cel comes on and stays on i cant hook up the scanner to it because it will read error because of the jumper harness..
    obd2 cars have the same jumper setup.
    gwinnett
    thanx reps when i can
    Senior Member EJdm's Avatar
    how do you know when to stop counting the flashing lights???
    Quote Originally Posted by EJdm View Post
    then there is a big pause between them... like so
    flash ......... flash .......... flash .......flash flash flash .................................................. ................................. and then the next set begins
    stop counting when the codes start repeating themselves.
