Thread: resistor box wiring help
    revolution big mac's Avatar
    Default resistor box wiring help
    i need help on hoe to wire the resistor box off my ej8's engine harness and put it on the harness on my eg hatch. any help will be repped!!!
    thanks ia!!
    aye bro .:Stirfry:.'s Avatar
    are you using the eg engine harness or the obd2 ej one??
    ATL DAsquad Member #9
    Don't I have to use the eg harness? Isn't the rule use the harness that came on the car? Or do I use the harness that's on the lsv and the ej8?
    hold on let start over your putting a lsv into a eg. correct
    Privateer Racing!!
    Duluth,Ga
    Dont cut the harness. On the driver side their is a plug with a cap on it. Remove the cap and find the 4 wires that go too the injector.
    THen de pin them from that plug and pin them into the resistor box plug.
    Then pin the one red wire from resistor box back into the engine harness plug and install the cap and you done...
    Privateer Racing!!
    Duluth,Ga
    If you dont have the plugs for resistor box, goo too pull a part and cut them off a car there, Trust me its alot easier and cleaner.
    I will look at my ej8 harness and see if I can take it off to put into the eg harness. Dam I wish I could drop it in with the harness that's in the ej8 lol
