Results 1 to 25 of 25
Thread: Neon Kit
    Tiz
    Default Neon Kit
    I just got a neon kit for my car. anyone know how to install them? I would greatly asppriciate some info to help me.
    emartu
    Lawrenceville, GA
    what are you needing help with??? the wiring or the mounting or both???
    Did you buy it? Later, QD.
    Aug 2001
    Charlotte, NC
    No Mike, He stole it...LOL
    '15 Chevy SS
    '16 K7 SXL SWP
    No. I just didn't think people bought neon kits any more, lolol. Later, QD.
    Tiz
    yeah i need help with both. yeah i bought from some guy i met(sp?) on here..
    Aug 2001
    Charlotte, NC
    So what are ya sayin?? lol. Although I went from neon to the LED undercar kit, Less hassle and less worry of breakage
    '15 Chevy SS
    '16 K7 SXL SWP
    they are pretty cheap now
    IA.COM Founder.
    Nov 2000
    stay away
    A.K.A Felipe Gomez Negrodamus's Avatar
    Daaaaaaknessss
    If your doing a neon kit the best materials are:
    1. Large 25 Gallon Metal Trash Can
    2. Gasoline
    3. Matches
    Tiz
    Quote Originally Posted by KingElli
    2. Gasoline
    3. Matches
    Wow thanks for the help ass hole WTF?? It was a simple question dont have to be an ass about it.
    Tiz
    Anyone wanna put it on for me ill pay them...
    ALL CAPS JITB's Avatar
    Its simple...Just like hooking up foglights. Just mount them wherever u want. make sure the neon tube isnt showing. so it will actually glow the under carriage of the car, instead of being like a 4 foot light bulb. Drill it to the car. And then just hook up the power and ground wire, to the switch. And wallah. Its simple...you can do it, just get someone to help u mount them. Just make sure your tubes dont show, at all. What color is the kit?
    dahlonega
    yes more rice i luv it lol
    DBlock
    tha ville
    Default yo!!
    bet his car will stand out more than yours!!! 1
    rice or not its his shit...so who cares. keep on tellin people what to do to their cars.
    I JUST DONT GIVE A FUK dereksi's Avatar
    If you got a body kit you might need a lift. But yea just drill into the body where you want them mounted. Kit should come with brackets to mount lights to body. And bolts. Hide the wire and mount transformer on flat spot on the motor. Wire the switch on the firewall through the door to the cabin. Sounds complicated but its really not. And PLEASE hide the tubes.
    Banned flysi00's Avatar
    hmmm...hold on, almost had it...damnit!!!
    ill install them for 25
    Tiz
    Color of the kit is red thx for the feedback im ganna give it a shot on sat. Ill make sure I hide the tubes the kit comes with the brackets to mount but where do I drill? and where do I wire the switch to? or wheres the firewall through the door to the cabin?(I'm not very car smart).
    Just drill it wherever u mount it. Just wire the switch to a power source on the car somewhere. i guess u can run the wires from under the car, to the engine bay and inside thru the firewall. Dont run the wires between the door hinges, or in that space between the fender. just find one of the spots were there is already wires being ran thru the firewall, and run it thru there. Ive never installed one before, so i dont know if it has extra switches and relays and all that.
    NANNERPUSS
    Dec 2003
    winder, GA
    dude i used some verry heavy zip ties when i put mine on or you can us4e there brackets but if you want some help if you havent already done it ill help ya
    Banned xplicitcivic04's Avatar
    ill do it for u for cheap
    NANNERPUSS
    Dec 2003
    winder, GA
    yeah but you will do it for cheep while ill do it for free cuse thats what i like to do
    yeah installin neon lights is super cool and fun guys!
    If you can get away with it, zip-ties are great things to have and you won't have to worry about punching a hole in something important. Even if you use the screws,back them up with zipties JUST in case you rattle a screw loose. It would suck to be rolling down 285 and have a 48" tube pop loose (it'd suck worse for the dude behind you!)
    There are several holes already in your firewall that will go into the footwell so you can get power to the switch straight from the battery. Look under the hood on the firewall near the battery. Somewhere on there they'll be a spot with a rubber grommet and a conduit ( a plastic tube ) full of wires running through it. There's probably more than one or two of these. Push a coathanger through the wall (*with the tip bent tightly ROUND!!!! no wire tearing!!!), pull back the carpet in the front of the footwell on the passenger side and look for the other end of that hanger. tape/wrap/whatever your power wire to it and pull it back through the wall into the engine bay. Attach it to the battery easy as that. You'll definitely want about a 30 amp in-line fuse and 8 - 10 guage wire for the power. Same for the ground. (( my long winded point is that you shouldn't have to drill a hole in your firewall b/c there's several already there for various wires. take advantage of what's already there ))
    Once you're done, take a shot at night and post it for us I've neon'd the hell out of my interior ( it's REALLY BLUE in there ). it's just a fun, cheap thing that keeps me busy and looks pretty and strange. I think I may be using too many..... they pulse when the subwoofer hits hard ! it's pretty funny
