Results 1 to 40 of 68
Thread: Your "Pre-Flight" checks.
    Default Your "Pre-Flight" checks.
    So everytime you get in the car, what do you usually do by habit before rolling out?
    For me its:
    1. Shut off Traction Control
    2. Check Mirrors.
    3. Check Fuel.
    4. Check Vacuum and volts lol
    5. Waggle the shift stick and place her in gear.
    -Turn kill switch on.
    -Fuel pump on.
    -Oil on.
    -Check gauges.
    -Ignition
    -Start
    i'm a got dang wallaby!!
    1) key in ignition
    2) engine start
    3) check gauges
    4) remember if i had proper oil levels
    5) wait for 2 bars and hit mad vtax
    Quote Originally Posted by PURE jdm View Post
    1) key in ignition
    2) engine start
    3) check gauges
    DAMN I want VTAX.
    Fuck Your AC130 browningboy7's Avatar
    Dec 2008
    1: Move the seat back because apparently leprechauns steal my car and drive it at night.
    2.Key in ignition and turn it forward to let my fuel pump come on because if I don't the car wont crank because it's a pos.
    3. Check Fuel.
    4.Crank and burn lots of gas.
    bump wish had the cash for a tranny
    Epic Foxbody Thread Crew Member #01
    BUY THE S2K THEN FOOL! ENJOY MAD VTAX....so much vtax womens panties fall @ the mear sound of it.
    Quote Originally Posted by browningboy7 View Post
    3. Check Fuel.
    What do you drive?
    Dec 2008
    What do you drive?
    DD is a 03 Tahoe.
    F.A.N.A.T.I.C. primespark22's Avatar
    1.search party to find my keys
    2.turn on my kill switches
    3.let cd load
    4.safely drive out of drive way
    5.then hit vtec
    92 DA9 with a b20 on 8lbs daily
    DALLAS 8-4 1st in the nfc east
    1-3-7-2-6-5-4-8 40th GT's Avatar
    Suwanee, GA
    Not to be the mom but no seat belts?
    1) seat belt
    2) ignition
    3) adjust radio
    4) adjust climate control if necessary.
    5) turn on lights/wipers if necessary.
    6) grab 1st (reverse if backing out) and go.
    Mine's the red one.
    slingshot sales ceo. ls-r teg's Avatar
    gwinnett
    1.e-brake down
    2.put it in gear
    3.turn the key in the on position
    4. pop the clutch cuz my battery is to weak to start it normally
    5. then hit lots of vtec
    STILLHAVE THAT PENIS ?????
    They should have never gave u niggggas vtec
    ALL CAPS JITB's Avatar
    Vent roof
    seat belt
    Crank
    Listen for new nosies (the joy of owning a 17yr old car)
    Engage Cruise Mode!
    enter car
    -wiggle stick into neutral
    -start engine
    -set radio
    -check mirrors
    -turn on driving lights (one click below headlights being on)
    -wait until the temp gauge has moved at least the width of one needle off of the lower peg, so I know I'm not driving on a dead cold engine (usually takes 2 or 3 mins)
    -if daytime, drive off, if night, fully turn on the headlights and drive off
    Earth
    Get in car
    wiggle shifter to make sure it's in neutral
    insert key
    turn key to the start postion
    realize I drive a 240 and it won't start
    remove key, exit vehicle
    curse @ vehicle
    get in Dodge Ram and drive away
    Certified Gearhead SeePlusPlus's Avatar
    Jul 2009
    Roswell
    1. Clutch in, start car
    2. E brake down
    3. Plug ipod in, pick song
    4. Check the mirrors
    5. Peel out of garage
    6. Open garage door
    I love my Z m3dic8d's Avatar
    L-burn
    Quote Originally Posted by SeePlusPlus View Post
    2. E brake down
    6. Open garage door
    You open the garage door after you peel out of the garage?
    BOOST3N tmoney11286's Avatar
    Midtown
    get in
    key in ignition
    put clutch in
    turn on
    rev the shit out of the engine
    look to see who though it was cool as hell
    drive away
    ///M6
    Step on brake and clutch. (idk why i step on brake)
    put car in neutral.
    turn key.
    Let the car warm up.
    Seat belt!
    check mirrors, pull down brake put in gear and ride out.
    C7 On_Her_Face's Avatar
    Duluth
    Acura:
    Clutch in
    Turn key
    Set radio
    Get to 8k RPMS as fast as possible to heat up the oil
    Corvette:
    Clutch in
    Press start button
    Let it idle go from rough to smooth
    Check all gauges gauges (ignore low tire pressure)
    Roll down windows
    Put on 60s on 6 or 80s on 8
    Pull out
    Burn tires if need be
    villa rica, ga
    look at my tires, start, watch oil press gauge, get a lil heat in her, then watch the road with one eye and the air/fuel gauge with the other
    MabletonSpeedShop member
    MCE Mafia supporting member
    honored to be MCE Dec'08 rotm
    Stang Mod slostang's Avatar
    Southside
    1. unlock door
    2. get in car
    3. wiggle the shifter into neutral
    4. start the car
    5. adjust radio
    6. fart
    7. roll window down because my farts are awesome
    8. RTFO
    Jun 2009
    79 Corolla
    1.Seat belt thingy (sometimes)
    2.key in
    3.turn key to "run"
    4. reach left hand over top of the steering wheel to turn key
    5.right hand to pull and hold choke (doesnt stay out after its been pulled)
    6.push in clutch
    7.turn key to "start" with left hand
    8.modulate throttle with right foot wait for car to fire up
    9. wait for car to idle right without throttle input
    10. adjust radio
    11. lower e-brake
    12 RTFO.
    Stereo Junkie TSiFTW's Avatar
    Apr 2009
    Open door
    Insert right foot
    Sit down
    Pull left foot in
    put hand on shifter
    put in neutral
    insert key in ignition
    turn ignition
    crank car
    listen to car
    get out of car
    pop hood
    see what the new noise is
    get back in car
    let it get warm
    roll windows down
    back out of driveway
    middle ga
    i leave my car running all the time and in gear doing a massive burnout so all i have to do is slide across the hood and jump in the window dukes of hazzard style and im out s0n!
    Flowery Branch, GA
    turn the car on
    pick something good on the ipod
    roll all the windows down, unless its raining
    roll the fuck out
    Duluth
    Quote Originally Posted by japan4racing View Post
    Just like Bo Duke?
    \m/>_<\m/ dorin48's Avatar
    Canton
    Press button for flip-out key (VW)
    Press unlock button (primes the fuel pump)(correction, its when I open the door)
    Get in
    Neutral
    clutch and start
    seat belt
    radio
    wait for high idle to finish.
    Suwanee, GA
    Quote Originally Posted by dorin48 View Post
    Very cool.
    Mine's the red one.
    Daytona Beach
    Gust lock - Remove
    Flashing Beacon - ON
    Magneto Switch - ON
    Avionics Switch - OFF
    Master Switch - ON
    Flaps - Extend 30 degrees
    Primary Flight Display - Check/ON
    Exterior Lights - ON/CHECK/OFF
    Fuel Quantity - Left/Right - Check
    Low Fuel Left/Right Annunciators - Check
    Oil Pressure Annunciator - Check
    Low Volts Annunciator - Check
    Low Vacuum Annunciator - Check
    Avionics Switch (Bus 1) - ON/Check/Off
    Avionics Switch (Bus 2) - ON/Check/Off
    Pitot Heat - Check
    Master Switch (Alt and Bat) - Off
    Right Fuel tank quantity - Check
    Engine oil quantity - Check
    Left Fuel Tank quantity - Check
    Documents - Check
    POH - Available
    Garmin 1000 CRG - Available
    Parking Brake - Set
    Control Wheel Lock - Remove
    Flight Controls - Free/Correct
    Fire Extinguisher - Check/Secured
    Fuel Selector Valve - Check/Both
    Fuel Shutoff Valve - ON
    Elevator Trim - Check/TAKEOFF
    Alternate Static Source - Check/Off (In Fully)
    Mixture Control - Idle CUT-OFF
    Throttle - Closed
    Avionics Switch (Bus 1 and 2) OFF
    Electrical Switches - OFF
    Ignition Switch - OFF
    ELT Switch - Armed
    Windows - Clean All
    PFD/MFD - Clean
    Cabin Checklist - COMPLETE
    + 2 more pages on wings and empennage followed by all the other checklists.....
    Ramp out checklist
    Before Start checklist
    Engine Start Checklist
    Before Taxi Checklist
    Before Take off "Run Up" Checklist
    Before Take off Checklist
    Before Take Off "final items" Checklist
    Climb Checklist
    Cruise Checklist
    Descent Checklist
    Decent Final items Checklist
    After Landing Checklist
    Shutdown Checklist
    Ramp In Checklist
    Secure Checklist
    Gust lock - Remove
    Magneto Switch - ON
    Master Switch - ON
    Pitot Heat - Check
    Documents - Check
    POH - Available
    Parking Brake - Set
    Throttle - Closed
    ELT Switch - Armed
    Windows - Clean All
    PFD/MFD - Clean
    Ramp out checklist
    Climb Checklist
    Cruise Checklist
    Descent Checklist
    Shutdown Checklist
    Ramp In Checklist
    Secure Checklist
    DAMNNNNNN YYYYOOOOUUUUUUUU
    i was going to use an actual preflight checklist that i do.
    Daytona Beach
    Quote Originally Posted by redrumracer View Post
    Well what do you expect me to do? This is one of those times the question really does apply to me.
    Are you using a 172?
    423 KING
    Chattanooga, TN
    1. unlock the doors
    2. start up
    3. oakleys on
    4. windows down so the haters can see me
    5. go slow cause speed bumps suck
    18x9 +24 18x10+22
    In the Fucking A
    Street car....
    Turn Key
    GO
    Race car
    Week before
    Get car aligned (yes every fucking time)
    Day before Event
    Check Tires
    Check Pressure
    Fill Tank
    Adjust Harnesses (for fatness)
    Crank car and bring to temp
    Check all vitals
    Put car on Jack Stands
    Bolt check entire car
    Review Track Map
    Go over previous data acquisition files
    Go over video from previous sessions
    Day of
    Check tires and lugnuts again
    Warm up car
    4 hours before
    Prep myself mentally
    Mindset preparation (somewhere between angry and crazy will do)
    3 hours before
    watch track video or go over track map again
    2 hours before
    enter state of zen
    1 hour before
    ...music time
    30 minutes before
    start car
    10 minutes before
    Get in and resume the zen state
    GO time bitches
    1st lap, atleast one big cold tire slide to remind myself what the fuck I'm here for
    2nd lap DIE MOTHER FUCKER DIE MOTHER FUCKER DIE
    KILL MODE
    I fucked İhris's mom
    Suwanee, GA
    Got pics of the race car?
    Mine's the red one.
    :noitacoL
    Get In
    Ignition
    Buckle Up
    Adjust Rearview
    Adjust Climate
    Put in Europe - "The Final Countdown" CD
    Pop my collar
    Roll out.
    In the Fucking A
    Quote Originally Posted by 40th GT View Post
    Old pics,....looks like a white STI. Ill shoot some pics of it later this week when we drop the new motor and tranny in.
    naaaa, we fly pipers, a warrior.
    Daytona Beach
    I'm still in the 172 Nav3. We also use Piper Aeros and Piper Seminoles for the multi engine ratings.
    The best plane is the Super Decathlon for upset training. I wont be in that till i take the commercial course.
    Here is live vid of our flight line.
    http://southramp.db.erau.edu/view/index.shtml
    hit the auto start button
    wait 10 mintutes or so before going to car
    turn off alarm
    get in and find a good playlist on the ipod
    get back out to make sure the 26s are clean and sexy
    get back in to throw it in drive and go.
    no seat belt for me
    I was going to post the startup sequence for the Rolls Royce Silver Ghost which included something about flooding the carburetor, something about a trembler coil and magnetos...I don't know.
    -Unlock button
    -Unlock button again because it doesn't like to work all the time
    -Remove conventional key from the fob to unlock manually
    -Get in quickly and stick the key in ignition to kill the alarm
    -Apologize to everyone and bore them to death about why my car did what it did and then show them my cool key fob
    -Fasten seatbelt
    -Have a five second day-dream about actually flying a real jet
    -Shift to neutral and do a wiggle-check
    -Depress clutch
    -Turn the car on
    -Clear out false-alarm error messages
    -Cleared for take-off
