Results 1 to 25 of 25
Thread: what do i need to do this swap?
    Certified Gearhead bigbadjohn07's Avatar
    centre,al
    Default what do i need to do this swap?
    i want to swap my y7 head and intake mani to the y8 head and intake mani.
    i might have a head that only needs the v-tech solenoid to be complete.IDK yet i haven't picked it up yet
    after that i know what i need as for as the intake mani goes thanks to the other diy listing on that subject so any help on the head and how to hook up v-tech and wire it up or whatever will be very much appreciated and
    WILL REP ANY INFO THANKS.
    Jul 2009
    knock sensor wiring
    centre,al
    thanks
    roberta
    roberta
    i also think this needs to be moved to the general tech
    YR88 Win! Romeo's Avatar
    Middle Ga.
    Either wire in the 3-wire iacv or get an auto TB. Wire vtec. and a few other little things. Not hard at all.
    centre,al
    Default ?
    Quote Originally Posted by jcs View Post
    well i seen general questions about IA is the reason i didn't put it in there
    centre,al
    thanks guys
    roberta
    no prob gl with it bro
    rolla rollin
    middle GA
    for starters you will need new head bolts cause when you take yours out you cant use them agian because they are stretch bolts! you will also need a new headgasket just to be safe! and a vtec ecu not sure on the ecu code for ek but you can get a jumper harness and run a p28!
    Middle Ga.
    Quote Originally Posted by J-ROCK View Post
    That's actually wrong. You can re-use the headbolts. You'll need to add about 5 extra pounds when you torque them down. Although getting new head bolts is the better way to go. The ecu should be a p2e for the OBDII, Not 100% sure.
    I'd go with the P28. For one, it only reads one O2 sensor.
    Is not a male
    South southside.
    Quote Originally Posted by Romeo View Post
    pretty sure It's a p2p, not p2e though
    Middle Ga.
    Quote Originally Posted by Kourt View Post
    One of those 2. Lol.
    rolla rollin
    middle GA
    so basically your saying get new headbolts
    roberta
    i have seen oh so many who reuse theirs
    Light Tuned
    you can reuse headstuds
    the county
    maybe its me, but could he swap the head, and use the y8 harness? to save time on wiring in the vtec and whatnot?
    rolla rollin
    middle GA
    Quote Originally Posted by MugenCrx View Post
    but would YOU re-use headstuds? cause i would get arp just for the insurance that i wont have to fix anything
    centre,al
    ok im getting new head studs now all i need to know about is all the wiring situation
    thanks guys keep it coming
    yall are helping a beginner motor builder lol
    so reps for info
    West palm beach
    NO ADVERTISING
    -IA MANAGEMENT
    Senior Member DustnU's Avatar
    I'm on a boat!!
    I typed in d16 head swap in googlr found a great write up!!! withj pics and everything
    Work in progressneed slicks!
    VTEC.
    "Cool car" less.
    Anti-Nutswingers Crew - Member # 001
    southside ATL
    what about the oil squirter thingy on the intake mani side..between piston 2 and 3.
    also i would just put pm7 pistons and a nice cam on the y7 head
    BABIES "R" US crew
    Apr 2009
    warner robins
    a vtec ecu some wires and solder i dont recomend but splices they wont last forever i aint hard you could probly find a how to on google or somthing let me know how it goes and you gotta run some oil lines to the head for vtec
    your mom loves me
    I Ride Low S.Brewer's Avatar
    Sep 2009
    Columbus GA
    GL with this. I am gonna go Y8 head and ecu on my DPFI D15b2. I know as mentioned, head gasket, ecy, intake and may wanna re do some seals and all while its apart. GL!
    -EASTCOASTEFCIVICS.COM- For Sale call or txt 706-615-2205 thanks Stephen
    *LOW, SLOW, AND BANGIN'*
