Results 1 to 20 of 20
Thread: no power
    F.A.N.A.T.I.C. primespark22's Avatar
    Default no power
    ok i have an issue,ok my sister has a 95 civic ex with a d15b auto tranny,her car is loosing power,when you floor it it slowly pics up speed ans starts stuttering,so i took out the fuel pressure gauge out of my DA and put it in her car pressure is fine.Distibutor is fine new spark plugs,oil filter and the car has no cel's what can it be???
    92 DA9 with a b20 on 8lbs daily
    DALLAS 8-4 1st in the nfc east
    do a compression test, good numbers?, then needs a better tune up. bad numbers? well, no point in asking then
    Norcross
    timing
    Quote Originally Posted by j0nbunklah0m View Post
    timing
    or that, slipped my mind
    thanks guys ima check that now
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    timing x2....
    98 Acura Integra LS-DD
    ??????????????????-project
    Jul 2009
    clogged cat
    somewhere, GA
    check timing and report back
    '82 TE72 SR5 Sport Coupe
    3tc
    J.R
    Down South
    Quote Originally Posted by D3UC3S View Post
    X2, but purple power can be correct to (compression test)
    One Curve At A Time
    So you drive a honda and it has no power.....I dont see a problem?
    LOL sorry, coudlnt help it Goodluck!
    97 DX Civic w/ H22 FS
    EE OG Revmaynard's Avatar
    Actually it doesn't say anything about his car not having power.
    Bozzio for president.
    the county
    i wouldn't say the timing just yet. but i wouldn't rule it out. try the compression test first and see what the numbers say.
    GWINNETT IS GREAT!
    i say if it does not turn out to be timing...look inside the dizzy cap...and examine the dizzy again
    Stang Mod slostang's Avatar
    Southside
    Quote Originally Posted by FlipKing View Post
    i was thinking the same thing
    georgia
    my ef is doin the same thing,just found out its the vss.....
    yes i am....
    Southside
    Quote Originally Posted by THEONE View Post
    you shouldnt have a vss in an ef...
    roberta
    a bad wire possibly
    georgia
    Quote Originally Posted by slostang View Post
    thats what i was thinkin but i was told a code 17 or 17 flases on the ecu was a vss
    it acts like a vss when i had one go bad in my old s-10
    yes i am....
    It's all about JDM.
    CA to GA
    have u done a valve clearance adjustment(to proper specs)...
    AccuracyPerformanceAutomotive
    How do you know the dizzy is fine? DId you put new/good plug wires on it?
    500whp of spinnin fury!!!
