Results 1 to 18 of 18
Thread: crunch amp?
    roberta
    Default crunch amp?
    just wonderin if it was worth it 1000 watts by 2 but i know thats over rated,i plan on puttin it on 2 kicker comps in a memphis box rated at 300 rms just wonderin if its even worth the money 75
    Stereo Junkie TSiFTW's Avatar
    Apr 2009
    If it is an old school Crunch made by ZED then definitely, but I highly doubt it is as they are rare now. Even if it is a newer one as long as you just want some decent loud bass then it should work fine.
    roberta
    yep thats kinda what im lookin for cause i got good mids and highs
    Apr 2009
    If it is a newer amp it is a lower middle of the road. You will be happy as long as you aren't expecting crystal clear bass and don't want to shake the rearview of the car that is 3 cars in front of you.LOL It will give you a decent loud bass though.
    roberta
    well i had a kenwood class d a older one just and loved it just wonderin will it compare any??
    For $75, that is not bad. I now have Crunch instock since I am stocking Hifonics (MaxxSonics). They are decent and will get the job done, but nothing amazing. Also cut that 1000x2 by about 50-60%.
    roberta
    holy mother of god i was lookin for a little more than that
    Apr 2009
    Quote Originally Posted by jcs View Post
    Nope. And I would say a little closer to the 60%
    Yeah, that is the max rating...not rms. They do not even list a rms power rating is never a good thing.
    roberta
    ok well i might re-think that then...^what would you recommend for my kickers
    What model Kickers do you have?? Ohm load??
    roberta
    12 inch kicker comp 4 ohm 500 max and 300 rms i think
    roberta
    07c124
    The best deal I have now is the Kenwood 8104D Mono Class D amp. It would give you 250rms per sub, so would be very good fit. $110 for the amp.
    roberta
    damn i sure wish i could swing that...if one of my buddies cant find his rockford fostgate ill see what i can do thanks for all the help and reps have been given
    Let me know. I will poke around the inventory a little more to see what I have for a good price.
    roberta
    ok thank you...
    TopNotch Audio guy! lovinmydodge's Avatar
    um..... correction I talked to the head tech at maxxisonics. Don't remember the guys name but the same boards they use for the bxi line they use in the crunch amps. and as long has you have 14.1 volts or higher it will do what its rated at. but think of this. if you are running single 4 ohm subs and your running say 500 rms x2 at 4 ohms. realize this, you will have impeadence rise. so you may be seeing something like 4.6 ohms and will see effictively like 380 to 400 watts rms. and if you are unable to hold a min of 14.1 volts at full tilt you will drop even more. say you drop 14.1 to 13.7 you loose 18% so at 1000 rms x .18 = you will lose 180 watts so you will only get 820 watts rms max so you will only see about 250 to 300 watts rms at most! for the price you will get good power and decent sq. Not a show winner for sq but good enough for most DD.
