Ok I have a set of subs I no longer need .. I will get pics tomorrow..
Price $400
Amp Memphis PR1000.1 1000 Watt Mono 1 Channel Amp Amplifier
SPECIFICATIONS PR1.500 PR1.1000
RMS Power 4 Ohm 150 watts x1 300 watts x1
RMS Power 2 Ohms 300 watts x1 600 watts x1
RMS Power 1 Ohm 500 watts x1 1000 watts x1
Bridged Mono Power 4 Ohms x x
THD % 4 Ohms 0.75% 0.75%
Frequency Response 10Hz-400Hz 10Hz-400Hz
Dimensions 10" x 2.3" x 12.60" 14.60
2 p3's
Specs
The Rockford Fosgate P3D412 is a Stage 3 ‘Punch’ subwoofer, and this means serious bass. This 12-inch 4-ohm subwoofer features literally bulletproof construction, with a Kevlar fiber cone designed to deliver only the highest-quality frequencies that a subwoofer can deliver. The surround is made of poly-ether-ester to ensure that the tones produced by the Kevlar fiber cone are not muted by poor materials used in construction. The P3D412 contains two voice coils for maximum versatility, and thus the usable power range of this unit is from 100 to 500 watts, with a peak of 1000 watts. The P3D412 is also designed with cooling in mind, with air ducts that create a Venturi effect while the subwoofer is in use. All in all, the Rockford Fosgate P3D412 is one of the most well-rounded, best-performing, high-value subwoofers you can get your hands on.
