Results 1 to 33 of 33
Thread: question about car club/crew sub forums....
    H22a4
    Acworth
    Default question about car club/crew sub forums....
    how do you get a subforum for your team?
    if you need info on our team to make one
    look at the website
    www.TopsideRacing.com
    Biggs B
    "Does the Audi A4 has rear wheel drive or front wheel drive on models without quattro?"
    Russ
    "i dont know but i do know that i love timbawa - a strange rare esquisite dog from southern antarctica. Sells for $5,000,000,000,000 in Japan."
    ASAP AssHole WTF?'s Avatar
    Woodstock/Kennesaw
    since when is a rebuilt engine a mod?
    H22a4
    Acworth
    do you kno what mod stands for....
    say it with me m-o-d-i-f-i-c-a-t-i-o-n
    if its not how the car came
    then it is modified
    Biggs B
    Russ
    In the land of the slow cars
    you have to have 8 or 10 members post regularly.
    Your best bet would be to have a mod rename this thread after your club, then have your members post in here. Eventually with enough participation, you will have your section
    Quote Originally Posted by fresh_boi View Post
    then it is modified
    I think his point is, rebuilding a stock motor doesn't usually fall into the classification as modification. It falls into the classification or stock unless you modified the internals
    H22a4
    Acworth
    alright thanks stillaneon
    Biggs B
    Russ
    then it is modified
    A rebuilt engine is NOT a mod, man. Lolol, the fuck? Later, QD.
    H22a4
    Acworth
    its not the 96 engine that was in the 96 eclipse
    it is a 98 engine bored out
    learn to read
    Biggs B
    Russ
    learn to read
    Quote Originally Posted by cheap web site
    Drives: 68 VW Bug
    Mods: Rebuilt engine, scat carb, performance header and exhaust
    Accessories: Kenwood headunit, rare ansen sprint 15" rims
    Learn who you're dealing with, Boy, before you spout off at someone. Later, QD.
    learn to read
    As far as I know, it's still a 4g64. No reason to put rebuilt on the mod list when you could say 4g64 bored with (*insert supporting internals here*)
    H22a4
    Acworth
    alright sorry the site is not to your likings...
    geeze.
    i dont understand what the big deal is
    Biggs B
    Russ
    geeze.
    You started talking shit when you were informed that a rebuilt engine is NOT a mod.
    The site isn't that bad. Later, QD.
    H22a4
    Acworth
    no i didnt start anything
    all i was saying was that i consider a new engine a modification from the original.....
    and thanks
    Biggs B
    Russ
    A rebuilt engine is NOT a new engine. It's the old engine with new parts inside.
    An actual new engine is still not a modification, man. With that thinking, you're going to get laughed all over the place.
    In your "reasoning," last year I had to replace a busted driver's side window with a new one. So that means I can put down new side window as a mod? You sure about that? Later, QD.
    I modified my tires after they were worn out by replacing them.
    H22a4
    Acworth
    alright i get what your saying
    but do you get what i mean about the bored out 98 engine in a 96 being a modification?
    Biggs B
    Russ
    The engine from the 1996 and the 1998 Eclipse's are the same. So putting a '98 model engine in a '96 model car would NOT be a mod. But all the internal work done to the engine WOULD be a mod, yes. Personally (and I think an assload of people will agree with me), I would just list mods as what was done to the engine on the inside and not even note that the engine i from a different year car. Also if the new clutch is just a regular replacement, I wouldn't list it.
    As far as the Bug, which is what I saw the "rebuilt engine" as a mod, I'd remove that as a mod. Other than that, everything else is ok.
    Here's an example of what I did. I have a 1979 Civic. It had a factory 1.5L engine in it. I got an engine from a 1979 Accord (1.8L) and put it in my Civic. Since it's a bigger, little more powerful engine, that would be a mod. I consider it more along the lines of an upgrade, though.
    Hope I've helped. And I'm not trying to run your site or your club or tell you how to set up everything. Just trying to give you words of wisdom to help you along. Later, QD.
    H22a4
    Acworth
    alright yeah
    thanks
    Biggs B
    Russ
    Woodstock/Kennesaw
    yes i was referring to the bug, but i can tell you right now that being a dick to someone right off the bat is not going to help you get anything out of this site whether it be selling, buying, searching for info, etc.
    PS: heres -10 fo ya
    i can be a smartass too
    Woodstock/Kennesaw
    then it is modified
    if the car came with the engine, you pulled it out and replaced it with all new stock parts then how is it modified? So when i pull my motor and replace everything with better/stronger parts, what do you call that? Sorry im new to all this car stuff
    H22a4
    Acworth
    alright
    going to change the site
    but just to let you know
    the bug has SCAT H-beam rods, CP pistons, upgraded cams, power pulley, and dual rate springs with Ti retainers. Also dual port heads. IDK bugs but he says thats def. not stock....
    but i know what you mean about listing the things
    thanks for the inputs
    Biggs B
    Russ
    alright
    Now if he has all that stuff done, then yes, that is definitely modded. But like you said, list that stuff instead of just "rebuilt engine" and you got yourself a good mod list. Good luck. Later, QD.
    rollin 91 da egpower904's Avatar
    Dallas, GA
    hey thats my bug, i just didnt feel like logging into this old account to post my mods. couldnt find my password lol. alex did the website, alex just did all this posting, and i see he needs to learn a little forum etiquette. but dont hate on the bug, its a sweet little car and when i finish some tiny bodywork and paint, ill sell it for a good bit and go for something with booooost >
    Quote Originally Posted by egpower904 View Post
    I didn't see anyone "hate" on the Bug. In fact, that's my favorite car of the bunch. And why would you sell it? If I had a good running Beetle, I wouldn't think of selling it. Later, QD.
    Flowery Branch, GA
    H22a4
    Acworth
    i think he said the insurance on the bug was rediculous because no air bags any where in the car
    Biggs B
    Russ
    ^^^ That's weird. My 79 Honda has no airbags and I pay about $350/year for insurance. Later, QD.
    H22a4
    Acworth
    $350 a year?
    wtf?
    thats really good
    no he said it was over $200 a month
    Biggs B
    Russ
    ASAP's Ginger Kid
    Stockbridge
    Age probably has a lot to do with that.
    RIP Mom
    RIP Papa
    H22a4
    Acworth
    yeah thats true
    i mean the bug is a 68
    Biggs B
    Russ
    yeah thats true
    I think the dude was talking about the age of the person. Later, QD.
    H22a4
    Acworth
    i thought maybe he was saying yours was lower because it was a 79
    idk
    mines only about $100 a month
    Biggs B
    Russ
    ASAP's Ginger Kid
    Stockbridge
    I was implying the age of the individual, not the car. Although that doesn't help either lol. Parts are harder to find.
    RIP Mom
    RIP Papa
