Results 1 to 18 of 18
Thread: how to build a hatch for autocross
    BYT joesblk_teg's Avatar
    kennesaw/L-ville
    Default how to build a hatch for autocross
    im thinking about getting a hatch and do a swap in it i know i'll be running in street mod because of the swap but how would you guys build the car, like what type of engine (jdm h22, b18, ect..) and what type of suspension (coil overs, or springs and struts). turbo it or supercharge it or leave it NA some ideas would be appreciated thanks
    Hwy 315
    I also am a big fan of auto-x... I started with a stock B18B in my EG and went from there. For a novice driver, I would suggest an all motor, or a very small turbo setup. Peak horsepower isn't nearly as important as a smooth powerband and handling in this racing event (compared to drag or circuit racing) as the straights are very short and the corners are very tight. My friend has a Vortec supercharged S2000 that he tries to run in these events - needless to say he gets horrible times due to the fact he's a little too heavy on the throttle thus turning his auto-x run into a drift event.
    I currently have a built LSvtec with a LS tranny, Hayame coilovers, Yokohama RT-615 tires and more chassis braces than you can shake a stick at. I chose the LS transmission because i can hold second gear for the entirity of my run. (all the way up until 60mph).
    [/URL]
    Jesus Christ is my Savior
    H22a sucks, I'd leave the D motor in the car and just focus on suspension and learning how to drive better.
    No need for a swap to go fast.
    Example: Dood that auto-x's has the OEM D motor in his 91 Civic and kicks 90% of everyone's ass.
    kennesaw/L-ville
    well i also want for it to be a street car so i want a swap so on that note which engine should i get
    Hey man i have a hatch already setup lmk
    h22 will make the car nose heavy, i would go with a b18
    maybe a ls/ v-tech
    K20 is all the rage these days. :P
    Certified Gearhead dwnsthGABOY's Avatar
    Dec 2003
    Amsterdam, Netherlands
    Quote Originally Posted by Trey
    exactly, but those bitches are like 6k and about 2k to get it installed the "right" way. wink wink! LOL!!!
    Quote Originally Posted by admin
    whatever dude? 1,000,000 says you suck my dick while Fox News reports it
    kennesaw/L-ville
    how much are b18s running for i know h22 are like 2800 plus a g for install
    Quote Originally Posted by joesblk_teg
    naww, H22's all day long installed for less than that. The entire swap runs about $1,800 plus labor. The weight differance is minimal and the torque would be good to have for the tight & flat curves and short straights. AFTER learning control & braking, suspension is your MAIN concern....then taking off as much weight as possible & keeping/making the body as rigid as you can.
    If you got the time, money, & patience i'd love to see someone put the h22 in the back of hatch, preferably turbo
    Riding for Alzheimer dazn's Avatar
    atlanta
    i would just go for a b16 swap
    should really concentrate on suspension. Not just buying some good adjustable parts but actually setting it up.
    toe,camber,caster,dampers (compresson and rebound), weight balance, tire pressures, anti-roll bars are all very important and critical to dialing in a good time.
    If i were you, i would buy the suspension and wheel and tires first, spend a lot of time and research in setting up your car and getting just a little bit faster each time. Then, do a swap
    To all who say h22 sux or itll make it to heavy....The h22 setup is only 50-60 pounds more. The power is wayyyyyyy better than any b16. The b16 will NEVER have balls a h22 has. I have done LOTS of mtn runs with my h22 hatch. In all areas it WALKS all over my old 97 lude . My lude had MUCH more done to it than my hatch. I have a friend with a ctr swap and i can kill the car in EVERY area. The speed comming out of good corner with lsd is crazy. Also the h22 trans goes to 60 in 2nd and 100 in 3rd..!
    My setup...
    falken azenis rt-615s
    hx wheels{11 pounds}
    omni power race fullcoilovers
    front strutbar
    h22w/lsd
    I have hung with c-5s ,miatas ...ect in the mtns
    2009 zx10R
    2005 919
    2006 xt225 dual sport
    Quote Originally Posted by dazn
    He is right ..... other than the b16 unless you have never had a "fast" car ,then yea learn on the b16
    2009 zx10R
    2005 919
    atlanta
    Quote Originally Posted by Goinfasterthanu
    well thats the thing about autocross you dont need tons of power and especially if your car isnt set up, youll just spin tires, understeer, and such.
    hell look at miatas and the elise
    If he was going for circuit racing then go for the h22, but autocross cars should be nimble and easily change directions. not saying a h22 wouldnt hurt, but the b16 is the easy, cheap way to go. but like you said, its not much heavier, so really its just whatever he can find or afford i guess.
    but since he will prolly want to play a little on the street, then go h22
    __DailyGrind
    i would definitely go for a B16 swap...or a B18....H's and K's stands for $ and $$...i use to had an EG hatch with a B16 that i swap in for less than 2000$.....so its all in how u make ur contacts and choices..good luck tho
    DC5-R
    Gwinett
    If you got $$$ then go with suspension, now if you have $$$$$$ then go buy a set of TEINs with the electronic controlled dampers.
    T3h Foglights pwn j00!1/! Miranda's Avatar
    May 2001
    At a racetrack or classroom near you! ;)
    Lemme ask you a couple questions:
    First, why do you want the car to be in SM? Is this a daily driven fun car that you want to take out to autocross every once in a while, or are you trying to get serious about solo2?
    Second, how competitive do you want to be? Civics are kicking major ass in STS (a street tires, limited mods class). It would take a pretty big chunk of change to get the car really competitive in SM. Not undoable, but expensive.
    Finally, how much experience do you have? Trey's absolutely right when he says fix up the driver before fixing up the car. The best drivers can stomp the hell out of most others even when in far less prepped cars. Even if you are a seasoned veteran, I would really suggest spending a few hundred and going to a couple Evolution schools (http://www.autocross.com). Speaking from personal experience, those schools are monumental. I have Sam Strano (my Phase 1 instructor) partially to thank for my transition from a mediocre driver to a Nationals contender. They're worth every cent.
    So far as suspension goes, I would say it totally depends on the level of involvement in autocross you're going for. I wouldn't turn a daily driver into an uncomfortable comuter just to go to a local event every third month. But, if you seriously want to get into it, a good set of coilovers is a handy thing to have. Go to the Honda Tech motorsports/road race forums for info on the best suspension setups. There are some serious race kaa drivers there from grassroots to pro, so you will find some good info.
    Hope this helps:
    ~ Miranda (ex autocrosser)
    Anti-Keyboard Commando Brigade
    DC5-R
    Gwinett
    Quote Originally Posted by Miranda
    Hope this helps:
    well said
