Results 1 to 22 of 22
Thread: Car not cranking sometimes
    Default Car not cranking sometimes
    Ok so last night my battery was dead and tried to turn the key heard a click but wouldnt turn over. Jumped it and everything was fine so i figured it was my battery. I went to advanced auto today and got it tested and the results came out
    voltage: 12.57v
    Measured:935 CCA
    RAted:410CCA
    Temperature:72F
    my battery is more than what it should be so it should crank everytime. Now in the morning i put the battery back in and same thing, the first time i try to crank it it clicks, then i try again and its completly dead. I jump the car and its fine. Turn it off and try to crank it again and same thing happens first time it clicks, then i try again and its completely dead. Does my battery have a bad cell? Or is it Alternator/Starter issues.
    REps for fast answer
    i drive slow im_hung's Avatar
    location, location
    battery.
    troof. thanks
    ok so its not the battery, i just bought a brand new one and it does the same thing..
    need help asap please..
    southside ATL
    someone help this guy out
    bad ground, bad connections, could be bad starter if it comes down to it.
    start the car, take the negative off the terminal. report bakc
    Quote Originally Posted by NoWAyItZTOMmY View Post
    has nothing to do with car starting.
    well i was trying to eliminate the alternator not charging up the battery.
    check the grounds, power to starter, power to alternator. fuses.
    took off all the grounds cleaned it, terminals have no corrosion, even tried hitting the starter while trying to crank. the first time i try to crank it it clicks from the engine bay area, then next time i try complete dead
    forgot to mention i just bought a new battery too and shit does the same thing
    Aug 2009
    Lawrenceville, Georgia, United States
    Quote Originally Posted by k20ej8 View Post
    even though no corrosion on the terminals the inside of it could be corroded and bad
    and i would say its probably the starter thats the problem or the wires on it thats bad
    slingshot sales ceo. ls-r teg's Avatar
    gwinnett
    starter signal wire loose?
    STILLHAVE THAT PENIS ?????
    They should have never gave u niggggas vtec
    JDM TYTE AnthonyF's Avatar
    ...LOLOLOL
    Terminals loose would have been my 1st guess.
    -Ant.
    The Carbon Fibered R6
    Quote Originally Posted by AnthonyF View Post
    ...LOLOLOL
    -Ant.
    he called me last night an those was the first word out of my mouth. ive seen that so many times it aint funny an im sure u have also.
    ok so i just took the battery out of my brothers 97 accord its a diehard with 700cca and put it in my car. cranks perfect even turned it off and cranked it again started fine. but then i took it out and put my old battery on and it wont crank just one click then i try again and its dead. forgot to mention that last week i went to best buy to get my headunit installed and he did do some wireing around. should i get a bigger battery? wthhhh
    well if you took a bigger battery and it works fine, then there you go. answered your own question
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    yep. but DAAAYUMMM, 935 CCA'S? you got a battery on steroids?
    98 Acura Integra LS-DD
    ??????????????????-project
    Quote Originally Posted by Purple Power View Post
    not sure cause my old battery got tested 935, and still didnt crank. dont want to buy a 100 dollar battery and still have the same turnout.
    ls/vtak slut! SlamminCRX's Avatar
    Hinesville/Savannah, GA, Orlando, Florida
    get an optima red top lol
    well if thats the case, trade batteries with whomeever you traded earlier that worked
Tags for this Thread
