Results 1 to 14 of 14
Thread: misfire system
    Lawrenceville, GA
    Default misfire system
    what are they exactly? what do they do, and how do they work?
    how much do they cost?
    Senior Member b18hb's Avatar
    initial d, yo!
    Lawrenceville, GA
    damn right
    Drifter/Kneedragger
    Buford, GA, USA
    just turn the distributor on your car all the way clockwise and you'll have a low-buck misfire system.
    NalleyToyota Manager ct9a gsr's Avatar
    Kennesaw, Ga
    Get a 2-step launch controller and set it to cut ignition while dumping more fuel... it'll ignite the raw fuel in your exhaust manifold causing lots of explosions and misfires... also helps spool a turbo from a stop or in between shifts. =]
    www.toyotaofroswell.com
    Current: '04 S2000
    Past 700whp+ Cars: '03 Z06 | '94 Supra | '03 Evo VIII | Too Many...
    Lawrenceville, GA
    Quote Originally Posted by HiPSI
    yea you know I think I'll just pay you to do that
    last car that I fiddled around with its engine ignition system I ended up stripping threads... gotta love being a noob still
    care to explain like - how turning it clockwise would do it a lowbuck misfire ( I just want to be able to understand this etc )
    but lemme understand - a misfire system basically tinkers with your ignition sequence so that more fuel is burned?
    Lawrenceville, GA
    Quote Originally Posted by ct9a gsr
    hm, another question
    with that - is it on 24/7? or is there a way on how you can have the stock sequence then flip a switch and it'll change it to misfire ? (yea it might be a stupid question but I'm learning here)
    Hwy 315
    Quote Originally Posted by Stormhammer
    Yes to all of those. You can also activate the system via your TPS.
    [/URL]
    Jesus Christ is my Savior
    Lawrenceville, GA
    which one is it - or is it btoh? TPS? explain!!! =D
    Hwy 315
    You buy a launch controller and the system is installed in your car 24/7, I have seen people rig their MSD ignition to a switch (not the smartest idea IMO), This is a system that is integrated in with your ecu (just like hondata, it has it's own little fancy box) the way a launch controller works is when it's in "standby" mode and it senses the Throttle Position Sensor go past a certain percentage it activates itself and keeps your RPMs at a pre-designated point by killing the spark (like a rev limiter) but while it's doing this, it also dumps hella fuel into your cylinders causing an excess of fuel that isn't being used, causing a build up of atomized gasoline in your exhaust system. This (with the help of your launch controller's ignition timing) causes quite a few explosions in your exhaust manifold and assists your turbocharger to spool up or keep it spooled up between gears.... this is almost exactly what ct9a gsr said.
    [/URL]
    Lawrenceville, GA
    so there's no stand alone?
    Hwy 315
    it's more of an "override" type of thing
    [/URL]
    San jose, CA
    can't you buy this bee racing rev limitter http://www.bee-r.com/main/parts/revlimi/index.htm it seems like it would work
    Lawrenceville, GA
    translation? lol
