Results 1 to 4 of 4
Thread: FS: S14 Koni/GC setup
    Jan 2003
    Default FS: S14 Koni/GC setup
    My loss is your gain. Everything (except when noted) is brand new, never even mounted on a car.
    Front:
    -S14 Koni yellows already inserted into stock tubes
    -7" 400# 2.5ID Hyperco springs
    -Ebay special camber plates
    -TechnoToyTuning upper hats
    -Ground Control bump stops, already trimmed
    -Roller bearings on the bottom of the springs
    -Most of the miscellaneous hardware, just need another small sleeve
    Rear:
    -S14 Koni yellows rebuilt and revalved to handle 300# at the minimum setting (tried to convert to externally adjustable, but Koni does not have a hollow rod long enough at the time)
    -7" 300# 2.5ID Eibach racing springs (used)
    -Ground control bump stops
    -TechnoToyTuning top hats
    -You can either use a stock top mounting solution or use aftermarket such as the Tein top mounts
    Misc:
    -a **** ton of random sleeves, washers
    -a few more TechnoToyTuning upper hats
    -a pair or two of used 5" Eibach racing springs, I don't remember off the top of my head the specifics, probably not very helpful for 240 setups.
    Located in Atlanta/Gwinnett. At this time I am entertaining local offers (packing and shipping will be a pain and expensive) and am not parting out. Asking for $1000 firm. I spent at least $1200-1300 collecting everything, the small stuff really adds up. If you are not local and are interested, email me maybe we can work something out.
    PLEASE EMAIL [email protected] that is the easiest way to reach me I don't check forums often.
    Jdm S15 Psw Jdm's Avatar
    Sep 2008
    Atl
    nice...glws
    Slidin Sidewayz...
    Jan 2003
    bummppp if you are looking for a good street/track setup... will outperform most of the cookie cutter jdm coilovers with crappy dampers
    ATL represent
    Ahh if only for s13.,
