Results 1 to 4 of 4
Thread: integra question
    Certified Gearhead nstygomez's Avatar
    Jul 2009
    marietta
    Default integra question
    well i bought a 00 ls and on the cluster the only thing that worked were the rpm and speed gauges and i went out and bought a new cluster and wen i hooked this one up the car temp gauge needle goes all the way up to hot like the car is overheatin but its not and the speed and gas gauges dont work only the rpm.. im i hooking it up wrong? or are the cables that hook up to the cluster messed up? or could a fuse be blown?
    SOUTHSIDE
    you have the wrong cluster did you buy one from a 2000 model because 94-97 are differant wiring 98 01 is the one you need
    Jul 2009
    marietta
    Well I kno for a fact the new cluster I bought is nt a 2000 model like mines but the gauges on my cluster dnt work well only the rpm one does.. ima sell the one I bought nd buy a 00 one or check my fuses
    Atlanta... everywhere on i85
    change the lil green map lookin thing thats on the back of cluster.... just swap them out that should fix it..
