Results 1 to 14 of 14
Thread: Spark plugs went bad fast.
    Norcross
    Default Spark plugs went bad fast.
    So a few days ago my car was like breakin up at around 4k rpms. I figured it was my spark plugs, because i havent changed them in a while(they ended up being burnt up n old). Once i changed them everything ran fine. But now it started doing the same thing again. I jus went to look at the spark plugs and they're really black and it has been less than 1k miles. What would cause this?
    I used NGK plugs before and they lasted me forever. Right now i have in BOSCH plugs because i couldnt get the ngk ones gapped right.
    Car- Honda civic w/ B16
    Problem- Spark plugs went bad real quick.. WHY?
    thanks n reps for help
    SOUTHSIDE
    my fuel pressure regulator went bad once and kept burning my plugs up. it was making my car run rich so that's a possibility
    Norcross
    Quote Originally Posted by wrekonize View Post
    kool, thanks. i'll have to look into that
    you let the ppl at autozone talk you into to buying the bosch plugs? LOL!! get new ngk's and that should fix ur problem.
    Go Skateboard. ItsBlack's Avatar
    Last time I bought NGK's they went bad real fast, I ended up going back to the cheap autolites and they work fine. I never tried Bosch but I've only heard bad things..
    edit: wait, I did try Bosch gapless plugs. They didn't last long either
    ive swapped out bosch plugs in all kinda cars bc they usually only work good in vw and audi cars.
    Ive used ngk in all my engines and never had a problem at all. Hondas always get ngk imo. U have to get the right ngk's for ur car though, not just any of em.
    yeah, they (advance auto counter guy) told me which ones I needed
    Norcross
    Quote Originally Posted by BTEC View Post
    yea kuz i needed my car running and they only had the NGK's that needed to be gapped. n i was like, ok show me how to gap them, and they ended up bending the tips on 3 plugs. so i was like w.e ill just get the bosch's
    Quote Originally Posted by j0nbunklah0m View Post
    they didnt know how to gap plugs, dnt surprise me though. but im pretty sure if u get ngks back in it itll be fine. the boschs arent buring ur fuel completely and fouling out bc they dnt have and electrode (that pointy thing in the middle). i think that is the issue with them. not sure y they work good in vw'a and audi though.
    somewhere, GA
    NGK R....honda's love em and they are the cheapest ones
    '82 TE72 SR5 Sport Coupe
    3tc
    Ohio asshole.
    Quote Originally Posted by D3UC3S View Post
    thats a resistor plug.
    did you happen to change your plug wires, cap, and or rotor? could be crapped out and not gettin you enough spark.
    Jul 2009
    boshes are junkkkkkkkkkkkk
    go back to ngk.... or a copper core.
    platinum and iridium are garbage too
    i use ngk iridium plugs everytime and never had problems
    but yea boshes suck and shouldnt be used in a honda
    damn, i want that penis
    still searching! Hondatwin23's Avatar
    Atlanta\Lithonia
    i just picked up the v power or something ngk's now i need a distributor cap, rotor and wires
    http://twitter.com/LEGEND_STATUS
    1997 w/1999 civic w/ Built GSR...FS/FT
