Results 1 to 11 of 11
Thread: cam quesions!
    Default cam quesions!
    i guess is this is the right place for this. im wanting to get aftermarket cams. im looking at a stage 3 set up. i know that i have to upgrade my springs and retainers to run the cams but can i use my stock valves? also if i can use my stock valves cant this swap be done with out taking the head off of the block? im really wanting to do this with out taking the head off. any info will be great. thanks in advance.
    Aug 2009
    can quesions?
    Aug 2009
    you don't need to take the head off for this up grade>
    Quote Originally Posted by Austin? View Post
    can quesions?
    it says CAM all day long. some more input is needed before i do anything.
    stock valves are fine. me personally i would change them if the bugdet allowed. it can be done without changing the head just got to make sure u got a healthy motor.
    http://www.ehow.com/how_4477803_valv...ing-heads.html
    thanks man. i know my motor is fine. 63k on a 05 srt4
    Quote Originally Posted by blown_ss View Post
    np there is a tool u can get from snap on that does the same thing but its less ghetto ridged.
    oh i wont be doing it myself. i wish i could but i dont trust myself. i do everything else to my car, i just dont want to take the chance of screwing up my motor.
    good call
    MCD
    your gunna need a tune after. yes you can use the stock valves. the reason you need to upgrade springs is because the lift on the new cams that you will be putting in will be much greater than the stock ones. the stock springs will not be able to keep up and then you float a valve. that sucks. so they make tigher springs that can handle the heavy lift.
    you can get a compression tester without the guage on it and force a 140lbs of air in th cyl and change out springs without pulling the head if you have a valve spring comressor that work from the top like i did. the air will force the valves up and stay up in order to swap springs. this is the tool i used on my h22 in order not to pull the head after i built it and then decied to put valve seals in.
    like i said i was able to force air in cyl using the compression tester and a air compressor and this tool from up top without taking the head off. oh and always made sure the valves were pretty much closed when i did this so youll have to turn the bottom half to get it where you want it.
    Quote Originally Posted by whatever210 View Post
    yep. i have the knowledge to do it but im not willing to take the chance. i would rather have a shop do it instead of me taking the car apart and then not being able to put it back together. thanks for all the help guys.
