Thread: What cars did the 4AGE come in?
    Certified Gearhead Justin51982's Avatar
    Kennesaw, GA
    Default What cars did the 4AGE come in?
    Here is my situation.
    I am about to aquire a 1970 Lotus Europa. It is a complete car, minus the fact that the engine is missing.
    There were only 9300 Europa's made, period. So the original engine is almost impossible to come by.
    I've heard a lot of people swapping a 4AGE engine in it. I know it's a Toyota engine, but other than that, not too much. I don't follow Toyota, other than the Supra, that much.
    So if I can get help on this, I would appreciate it!
    Thanks guys!
    Fuck Your AC130 browningboy7's Avatar
    Dec 2008
    Carina 1983-1985 (Japan only)
    Carina 1985-1988 (Japan only)
    Carina 1988-1992 (Japan only)
    Celica 1983-1985
    Celica 1985-1989
    AE82/86 Corolla 1983-1987
    AE92 Corolla 1987-1993
    Corona 1983-1985 (Japan only)
    Corona 1985-1988 (Japan only)
    MR-2 1984-1989
    AE82/86 Sprinter 1983-1987 (Japan only)
    AE92 Sprinter 1987-1992 (Japan only)
    Chevrolet Nova (based on Corolla AE82)
    Geo Prizm GSi (based on Toyota AE92 chassis) 1990–19
    Carina 1996-2001 (Japan only)
    Corolla 1991-2000 (Japan only)
    Corolla Ceres 1991-1998 (Japan only)
    Sprinter 1991-1998 (Japan only)
    Sprinter Marino 1991-1998 (Japan only)
    bump wish had the cash for a tranny
    Epic Foxbody Thread Crew Member #01
    Kennesaw, GA
    Thanks for your help
    Dec 2008
    np.
    RedHenRacing #02 Stuntman G's Avatar
    Jul 2009
    My cuz has the '88 with a 4agze (supercharged) and that is a bad mama jama. drop one of them in that lotus chassis and youll be set.
    INSIGHTFUL DIALOGUE ANALYSIS: Actually, Hector, that is not what we call valet parking. Valet parking is where someone parks your car for you. You just pulled your car up to the front of the store and got out. We just call that parking.
    I MAKE THESE
    Certified Gearhead shubert's Avatar
    jasper/canton
    see also for performance.......
    ae92 levin
    ae92 trueno
    ae101 levin
    ae101 trueno
    the ae92 trueno's had the legendary 20v's in them. thats right 5 valves per cylinder and ITB set up from the factory. the silvertop early model 20v was MAF based and produced around 160hp, but had better tourque ratings than its later predessesor the black top. with the silvertop though you cant enjoy the ITB's because of the MAF based system , most eople find a blacktop ecu and harness and convert it to MAP. to enable them to run ITB's. also not to forget these engines have toyotas VVT (like vtech) and rev to 8000rpms.
    the ae101 truenos , have the 20v black top. its got the larger ports and gives better top end performance at 165hp and is ready to run ITB's , due to its factory map setup. but low end tourque isnt quite as noticable as with the silvertop. the black top has lighter smaller internals which allows it to rev quicker and higher at 8200 rpms.
    the ae92 levins , have a 4agze in them. these are factory supercharged with 10 lbs of boost resulting in 160 hp. but have gobbs and gobbs more torque than the n/a varients. most ae92 gze's are MAF based , and most owners use this block to convert to turbo. seeming as toyota already took care of the dirty work by factory forging the crank , rods , and pistons , as well as semi ceramic coating the pistons. 350 hp can be seen on stock internals here safely. the 4agze in the later 2 varients ae92 and ae101 are pretty well sought after.
    the ae101 levins have the same forged internals , 10 lbs. of boost , and awesome torque but with some differences....the ae101 varient is map based , and is a DLI design meaning coilpacks , and uses a wastespark design like the evo. this engine produces 170hp.
    if im correct for what i know of the europa its a rr or mr vehicle meaning the engine is in the rear , and transversely mounted like a fwd is. well if the toyota tranny can fit as well , the black top has a available 6 speed close ratio lsd tranny mated to it in most cases. the 4agze has a close ratio 5 speed more apt to deal with the instanious torque of the gze's supercharger, and also sports an lsd...something to consider as well.
    in my opinion i would opt for the ae101 4agze...this engine with small modification can produce above 200 hp and lots of torque.
    also my opinion isnt biased in case you wonder...i have an ae101 heavily modified in an ae100 sedan (94 corolla) time attack car , and an ae101 4age20vbt in my ae86 gt-s corolla. also my wife has an ae101 4age20vbt in her prizm. prizm and ae100 corolla is fwd , and the ae86 bt is rwd. my gze has more torque and is way quicker even in the stock form than the bt. but the bt does have the upper hand in the upper rpm range on top end. the gze redlines at 7200 rpms , but the s/c runs out of huff at around 6000 rpms.
    hope this helps.
    heres you some visual differences as well for reference...old pics , but good enough.
    first up , the black top 20v.....note both engines can be horizontally opposed or transversely mounted.
    now heres the ae101 4agze DLI MAP engine , in stock form and modified....
    modified...
    stockish.....
    Quote Originally Posted by BTLFED View Post
    You are a load that should have been swallowed.
    86atlanta.proboards.com <-------Atlanta based ae86 and drift community!!
