Thread: what will get this off?
    building the new ef revized_DX's Avatar
    northeast ga
    Default what will get this off?
    my brother gave me these wheels about a year ago and at one point he ran the brakes metal to metal and it seriously messed up the wheels. i have tried EVERYTHING to get this stuff off to no avail! seems to be like rust becuase i guess he never cleaned the thing!(LAZY!!!) my question is wtf can i use to get this stuff off? i like the wheel and i wanna keep them but this "rust" is an eyesore and i wanna get it back to what it should be...
    the little bit i have gotten off i had to pretty much "chip" out with a flathead. but as far as cleaners go, nothing will take this off! the back side of the wheel is pretty much coated with it....
    any suggestions? thanks in advance!
    vanilla sky.
    sand it or use a wire wheel ur probably end up having to paint them/
    TopNotch Audio guy! lovinmydodge's Avatar
    this is a little late but there is a cleaning material for rust. its a jelly. works great on things that build up too. I'd try it. it eats rust but keeps metal's intact. maybe something I'd try on the back side in a small area to see if it helps... you can pick it up at ace.
    Mods- High flow cat, Flowmaster stage 2 exhaust, Intake, Lots of wiring upgrades, h/o alt, 2 18's walled, off 8000 rms custom interior VERY LOUD (152.3) on music and a 156.6 outlaw.( system sounds alot like this!!!
    F.A.N.A.T.I.C. primespark22's Avatar
    you can polish the lip and repaint the wheel,i would just polish the lip
    92 DA9 with a b20 on 8lbs daily
    DALLAS 8-4 1st in the nfc east
    MYOB, Ga
    you can just sand them hoes down..
    GECKOSquad
    NIKOND7000 Shooter | flickr
    Aug 2009
    DONT PAY ANY ATTENTION TO WHAT THEY ARE SAYING!!!!!!!! I had the same problem with a set that i had. Go to your local home depot or some place like that and get some aluminum acid. USE GLOVES. this stuff will eat your skin right up. If home depot doesn't have it they should be able to tell you where to go. If you cant find any, PM me and i can get some from work. After you put this stuff on there it is going to take any impurities in the metal out so you will have to polish them again.
