Results 1 to 40 of 177
Thread: Punisher 6 - Mazda 6 - Twin Turbo
    Default Punisher 6 - Mazda 6 - Twin Turbo - Current as Of Jan. 14th, 2012
    This is my ride. most know her as Punisher 6. i originally brought her for a DD while i built my other car. but when i totalled that other car (my escort) i started building this. and this is where we are at since i crashed my other car in 2008. i brought the 6 sometime in 2006.
    2004 Mazda 6s (was a base model)
    3.0L Duratec V6
    Had the nasty tan/brown interior when i brought it.
    Engine/Drivetrain:
    -Custom Twin Turbo Setup
    -2 Turbonetics T3 Super 60s A/R .36 Hybrid (ported compressor sides w/ 60-1 Hi-Fi Compressor wheels)
    -Custom 3" Turbo Inlets
    -Custom mounted Spearco Intercooler
    -Raptor BOV - vta
    -Custom SS 321 Piping
    -Custom 3" Stainless Steel Exhaust
    -Injector Dynamic ID1000 Fuel injectors
    -Fully Built Engine (Noble Hybrid)
    Blueprinted
    Stock Forged Crank
    Forged Wiesco Pistons (8:5.1 compression) w/ valve reliefs
    Forged Scat H-Beam Rods
    Clevite 77 Rod and Main Bearings
    Machined Oil Squirters
    Upgraded Oil Pump
    Mild head Port
    ST220 Valve Springs
    -Aeromotive 340 Stealth Pump
    -Megan Racing M-GT Carbon Fiber Turbo Mufflers
    -Vibrant Perfomance 3" Metal Cat & 3" Resonator
    -NGK Iridium IX (TR6 - colder) gapped @ .30
    -AEM Water Meth Injection System
    -AEM Methanol Injection Monitoring System
    -PowerMod Advanced Engine Management System
    -Mustang Cobra 4v Ignition Coils
    -TGNY Custom Ignition Coil Leads
    -EMI Suppressors added Throughout the electrical system
    -Throttle Body Coolant Bypass with T-fitting delete
    -Fidanza 9 lbs. Lightweight Aluminum Flywheel
    -Competition Clutch Stage 5 (4-puck sprung)
    -Twisted Visionz/TGNY TCS Auto Off module
    -MFactory Prototype Forged Helical LSD
    -ARP Ring Gear to Differential Mounting Hardware
    -Modified/Optimized EGR system modification
    -AWR Lower Rear Bone Mount
    -AWR Upper Transmission Mount
    -AWR Passenger Side Head Mount
    -N2MB WOT Box with 2-step and No-lift Shift Feature
    -TWM Short Throw Shifter
    -TWM Solid Shift Plate Bushings
    -TWM Shift Cable Bracket
    -Optimized 3.7L Throttle Body (75mm) w/ custom TB spacer "first to run the 3.7L TB"
    -Lightweight Aluminum Alternator Pulley
    -Fluidampr 10% Under-driven Crank Pulley
    -Modified Oil Catch Can (VTA, Baffled, Filtering Medium added)
    -NRG Engine Grounding Kit
    -NRG Chrome Hood Dampers(modified by me)
    -Rear hood weather stripping removal(for heat expelling)
    -Custom Polished Aluminum Cooling Piping
    -180 Degree Stant Premium Thermostat
    -Nitrous Express Intercooler Spraybar
    -Nitrous Express Proton Nitrous Injection System w/ Fly-By-Wire Controller
    -Ported Lower intake Manifold Runners
    -Ported Upper Intake Manifold (first to do it)
    -O2simulator
    -Battery Relocation to Trunk
    -ETC Electronic Throttle Controller
    Brakes and Suspension:
    -BC Racing Coilovers BR Type
    -R1 Concepts slotted and drilled rotors (front and rear)
    -Axxis High Performance Ceramic Brake Pads
    -Racing Beat Front Sway Bar
    -Racing Beat Rear Sway Bar
    -AWR Adjustable Sway bar Endlinks Front
    -AWR Adjustable Sway Bar Endlinks Rear
    -GT Spec 6-point Ladder Brace
    -Custom Frame Connectors
    -GT Spec Rear Trailing Arms
    -Autoexe rear trunk brace
    -Motul RBF 600 Racing Brake Fluid (Dry Boiling Point 593 degrees F)
    -Front Upper Strut Brace
    -Candy Blue Powder Coated Strut Bar Mounting Plates
    -Techni-Fit Blue Stainless Steel Brake Line Kit
    -Techni-Fit Blue Stainless Steel Clutch Line
    Exterior:
    -Autoexe GG-02 Front Bumper, 2-toned w/ black accenting(not sold in the states)
    -Cyber Full Rear Bumper (2-toned w/ black accenting)
    -Cyber Side Skirts
    -Monster Carbon Fiber Hood (Body Color Matched with CF show-thru custom Accenting)
    -Car-LED Black Housing LED conversion tail lights
    -The Retrofit Source: Clear Lense Bi-Xenon Projector Upgrade w/ Morimoto Mini H1 5000k bulbs
    -Wire Tuck (first V6 tuck)
    -Four way Brake-light Mod
    -06+ Mazda 6 Black Housing Headlights
    -Candy Blue Powder Coated Valve Covers
    -Candy Blue Powder Coated Charge Piping
    -Black headlight eyelids
    -Custom Flying M Emblems
    -Debadged
    -custom under hood mirror inserts by www.underthehoodinc.com[/URL]
    -Door Guard deletion
    -Custom Stainless Polished Engine Cover
    -Custom Stainless Fuse Box Insert
    -Blue LED headlight marker lights
    -Chrysler Pacifica Stereo Antenna
    -Aftermarket Sunroof w/ wind deflector
    -Hyperwhite Headlight turn signals
    -Fenders Rolled
    -Traklite Angle 18x9 ET40 Custom Powdercoated Wheels
    -Nitto NT-05 235 40 18 Tires
    -Powdercoated White Lugnuts - Inverted Style
    Interior:
    -Full Custom Interior Done by Gillin Custom Design - www.gillincustomdesign.com[B[/URL]] (too much to list)[/B]
    -Custom Steering Wheel Airbag
    -Blue LED dome lights
    -Sony CDX-M9900 cd/dvd/mp3 player head unit
    -Sony CDX-757mx ten disk cd changer
    -Kicker Solobaric L7 Subwoofer in custom ported box
    -Kicker KX600.1 mono class D amplifier
    -Blue LED door sill lights
    -Alfa Otto Racing Reverse Glow White Gauge faces
    -Stainless Steel Weighted Shift Knob (2 lbs) (Member Front1ine)
    -Lotek Tri-gauge dash pod
    -Glowshift Triple Gauge A-Pillar Pod
    -AEM Injection Monitoring Gauge
    -Prosport Performance Wideband A/F Monitor Setup (Evo Series)
    -Prosport Performance Boost/Vac Gauge (Evo Series)
    -Prosport Performance Oil Temp Gauge (Evo Series)
    -Prosport Performance Oil Press Gauge (Evo Series)
    -Prosport Performance Coolant Temp Gauge (Evo Series)
    -Prosport Performance Fuel Press Gauge (Evo Series)
    -Greddy Full Auto Black Turbo Timer
    -Greddy Profec B Spec-2 Electronic Boost Controller
    Future Mods :
    -Custom Sheet metal Intake manifold
    -Cryo Treated Transmission
    -Custom Driveaxles
    -Custom Traction Bars
    PHOTOS:
    Punisher Rig Front TVP4.9.2013 by Twisted Visionz Photography, on Flickr
    Punisher 6 (1 of 1)6.20.2013 by Twisted Visionz Photography, on Flickr
    tunnel shoot (2 of 2)6.26.2013 by Twisted Visionz Photography, on Flickr
    punisher 6 midhudson bridge (1 of 1)7.31.2013 by Twisted Visionz Photography, on Flickr
    untouchables 2012 (47 of 49)8.26.2012 by Twisted Visionz Photography, on Flickr
    punisher 6..... Damn, damn, damn! by Twisted Visionz Photography, on Flickr
    punisher 6 rolling interior (1 of 2)8.4.2013 by Twisted Visionz Photography, on Flickr
    punisher 6 rolling interior edit (2 of 2)8.4.2013 by Twisted Visionz Photography, on Flickr
    punisher6 graffiti (1 of 1)8.22.2013 by Twisted Visionz Photography, on Flickr
    punisher 6 by Twisted Visionz Photography, on Flickr
    That Sky tho.... by Twisted Visionz Photography, on Flickr
    Punisher 6 Light Test 2013 (1 of 1) by Twisted Visionz Photography, on Flickr
    A Couple From My trip Down to Florida at the End of October:
    episodeM coverage 2013 (25 of 69)10.23.2013 by Twisted Visionz Photography, on Flickr
    Punisher 6 at Episode M by Twisted Visionz Photography, on Flickr
