Results 1 to 4 of 4
Thread: multi point question
    georgia
    Default multi point question
    i know this topic has been covered 10000000000 times hehe
    im workin on a dual to multi point conversion
    and i keep reading on it and some people say i need a obd0 black harness.what the heck is that? and where can i find ecu pins and do i really need them for this? oh and where the hell can i find the injector harness/clips with wires? i cant find those anywhere not even ebay haha. any info would be appreciated.
    yes i am....
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by THEONE View Post
    Pull-a-part is your best friend. You can get the clips and injectors from an OBD1 SOHC and eliminate the resistor box wiring. You will only need one ECU plug because you will only need probably 2 pins out of it. You don't need any harness. You will need the harness side of the distributor plug if you want your A6 distributor to be plug and play. (this is the hardest plug to find) The throttle position sensor wires you will have to extend and swap the two outer wires, but you can use regular auto parts store wire for that.
    West palm beach
    or just make it easy and go to rywire.com
    General Tech Hater
    easier, but way over price.. last i checked it was 300 to get your DPFI harness converted to OBD-1 VTEC.
