Thread: The new Golf R!
    \m/>_<\m/ dorin48's Avatar
    Canton
    Default The new Golf R!
    Article from vwvortex.
    Hot on the heels of the new Golf VI and Golf VI GTI, Volkswagen has released the first details and photos of the new "R" model. Unlike past "R" models like the R32 where the engine displacement was part of the name, the numeric designation has been dropped and the model is now simply called Golf R. More importantly, the new model breaks with past Golf R tradition and is now powered by a 270hp turbocharged 2.0l four-cylinder (2.0T) borrowed from the new GTI and sent to the weight room for strength conditioning to the head bolts, connecting rods and engine block.
    The new Golf R utilizes a newer version of the Haldex all-wheel-drive system that does not require slip to engage AWD. Rather the new system is pre-primed and looks at throttle position and torque being delivered to determine how much clutch-pack locking to initiate. What this means is if the car is floored from a standing start, the electronics automatically assume that maximum torque is required and pre-engages the AWD system to maximize grip for the launch. When the car is normally driving down the highway in a situation where AWD isn't necessary, the system disengages the AWD clutch pack to reduce frictional losses and improve economy. Overall the new system is far more responsive and progressive in its behavior.
    Visually the new Golf R has a completely new front bumper similar to the European Scirocco R model with larger intakes, LED lighting and much more aggressive sculpting. The headlamps are blacked out to match the black grill and new "R" logos are positioned on front grill, rear hatch, door sills, steering wheel and seat headrests. Two different seats are available with the base seat being the top sport seat from the GTI with new cloth inserts and an optional Recaro "shell" seat available in cloth or leather.
    The Golf R chassis also received further improvements over the GTI with larger sway bars front and rear, more aggressive shocks and springs that sit nearly an inch lower. Brakes have been upgraded to 13.6 inch rotors up front and 12.2 inch rotors in the rear. Front calipers are painted gloss black with "R" logos.
    So what does all this mean for us here in the States? Volkswagen of America won't officially say whether the Golf R is coming to America. We know they are looking at the numbers to see if it makes sense for our market. Internally Volkswagen of America would like to see both two and four door models with a choice of DSG or six-speed manual offered, but only if it can be done at the right price. We'll of course keep you informed on the latest news as it becomes available. Meanwhile the official Volkswagen AG press release for the European market follows below...
    Wolfsburg/Frankfurt, September 2009. Automotive passion – even in 2009 it still has something to do with power and performance. At the IAA, however, Volkswagen is demonstrating – in the world premiere of the new Golf R – that fuel consumption values can even be corrected downward in the high-end sports car area. And indeed without even a hint of a compromise in dynamic performance. On the contrary. Traditionally each new R version of this model series bears the title “strongest Golf yet produced.” With a power of 199 kW/270 HP (at 6,000 rpm), the new Golf R is continuing in this dynamic tradition; the previous model transferred 184 kW/250 HP to its all-wheel drive system. The highlight here: While the now retired Golf R32 processed 10.7 litres of fuel through its fuel injection system every 100 kilometres, on the new Golf R the figure is just 8.5 litres – 2.2 litres or 21 percent less! CO2 emissions were reduced from 255 to 199 g/km. Like all R models, this one was also conceptualised by Volkswagen Individual.
    The increased economy is joined by stronger performance. The new Golf R sprints from 0 to 100 km/h – also via all-wheel drive – in 5.7 seconds. On the previous model, the stopwatch stopped at 6.5 seconds. The new model puts the 1,000-meter mark behind it in 25.4 seconds, while the already masterful Golf R32 shot past this mark in 26.7 seconds. The Golf R does this even better with the optional DSG gearbox, sprinting to 100 km/h in a sensational 5.5 seconds and requiring just 8.4 litres petrol per 100 kilometres (equivalent to 195 g/km CO2) at the fuel pump.
    The enormous efficiency gain of the new Golf R is not based on some magic trick, rather it is the result of highly advanced downsizing. Its legendary predecessor generated its power from a displacement of 3.2 litres (“32”) and six cylinders. In the new model, this is done with four cylinders and 2.0 litres of displacement – a highly advanced direct injection petrol engine with turbocharging (TSI). At the fuel pump and on the winding mountain road, this high-tech alliance is superior to a classic six cylinder unit with multi-point injection. Proving that even the sound of a four cylinder can leave a strong impression are the fifth and sixth generations of the Golf GTI, which is also powered by a four cylinder TSI. And the Golf R exhibits an even greater “sound range.”
    The TSI’s torque characteristic is just as impressive. By comparison: The six cylinder of the previous model developed a maximum torque of 320 Newton-meters (236 ft-lbs. of torque) at 2,500 rpm. And that was already remarkably good. The turbo four-cylinder direct injection engine of the new Golf R, on the other hand, transfers 350 Newton-meters (258 ft-lbs.) torque to the crankshaft, which is also available starting at 2,500 rpm, but it can maintain this peak value up to 5,000 rpm. So the new car delivers a fascinatingly high level of basic dynamic performance. The Golf R32 and Golf R are really only equal in one discipline; they both have a top speed of 250 km/h (electronically limited on the Golf R).
    TSI of the Golf R
    The EA113 series direct-injection petrol engine is used in the new Golf R; its turbocharger makes it very flexible and variable right up into the highest performance ranges. The 1,984 cm3 TSI’s specific power is a respectable 100.3 kW/136.6 HP per litre displacement, and its response is just as impressive. The engine’s power can be spontaneously summoned in the blink of an eye throughout its speed range. The engine also impressively underscores its potential acoustically. Visually too: Its two chrome tailpipes can be seen at the centre of the bumper under the diffuser integrated there – an “R trait” that the previous model also displayed.
    The four-cylinder engine develops its tremendous propulsive power via a turbocharger (up to 1.2 bar boost pressure) with intercooling. The engine, with a weight of just 152 kilograms (335 lbs.), is controlled by a fully electronic engine management system with E-Gas. The cylinders of the four-cylinder engine have been equipped with reinforcing bolts, unlike less powerful TSI versions. Also designed to be stronger are the connecting rods, so that they can reliably transfer the engine’s high torque to the crankshaft. Last but not least the cylinder block was also reinforced to handle the aggressive engine forces.
    New all-wheel drive on the Golf R
    As standard equipment, the Golf R transfers the TSI’s power to the road via the latest generation of Volkswagen’s 4MOTION all-wheel drive system. Compared to the version implemented in the Golf R32, the system underwent significant advanced development. Above all, power transmission between the front and rear axles – especially the all-wheel differential that operates in an oil bath – exhibits clear advances compared to the previous generation. The most important one: Activation of the all-wheel differential no longer requires a difference in speeds between the front and rear axles.
    That is because, different than on the previous generation, for the first time an electric pump is used to build pressure. The electric pump supplies oil to a hydraulic reservoir whose working pressure is 30 bar. A control module computes the ideal drive torque for the rear axle and controls, via a valve, how much oil pressure is applied to the working pistons of the multi-plate clutch. The contact pressure at the clutch plates rises in proportion to the desired torque at the rear axle. The amount of torque that is transferred can be varied continuously with the magnitude of the pressure applied to the clutch plates. Compared to the previous 4MOTION generation, the system operates independent of slip, since the system’s working pressure is always available. When starting up and accelerating, this prevents spinning of the wheels at the front axle more effectively, since the control module regulates the torque distribution based on dynamic axle loads. In extreme cases, nearly 100 percent of the drive torque can be directed to the rear axle. This results in further gains in active safety and dynamic performance.
    Sport chassis and brakes on the Golf R
    When it came to the chassis, development engineers were able to adopt the first-class system in the current production Golf. This means: In front the familiar McPherson strut suspension with helical springs and telescoping shock absorbers; and at the rear a multi-link suspension ensures that the standard ESP seldom needs to intervene. Nonetheless, the basic layout was transformed into a sport chassis with ride-height lowered 25 millimetres, and the springs, dampers and stabilisers were completely retuned to match.
    The brake system was also modified for the higher level of driving performance on the Golf R. In place of a 16-inch system, a 17-inch brake system is used with internally ventilated discs all around and R-specific brake calipers painted a high-gloss black with R logo. In front the discs are 345 millimetres in diameter, and 310 millimetres at the rear. The electronic stabilisation program (ESP) was also modified. It can be switched to a new Sport mode via the ESP button. During very fast and curve-filled drives – as on a circuit – the ESP system delays intervention, enabling even more responsive handling properties. The electro-mechanical power-assisted steering of the Golf R was also given a sportier characteristic. If the sports car is ordered with the optional DCC dynamic chassis control option, the power-assisted steering even assumes a specially tuned characteristic for each of the system’s driving modes (Sport, Normal, Comfort).
    The chassis maintains contact with the road through its standard newly designed 18-inch alloy wheels (“Talladega” type) with 225/40 tyres. As an option, the same wheels are available in a 19-inch version with 235/35 tyres.
    Exterior features of the Golf R
    Like the first two generations of the Super Golf (I starting in 2002, II in 2005) and the new sister model, the Scirocco R, the new Golf R too sports a completely modified set of exterior and interior features. Volkswagen designers, led by Klaus Bischoff, have given the Golf R an independent image with a bundle of well-coordinated refinements. The Golf R unmistakably marks the peak of the model series, and the quality of its styling follows the basic design language of “La Semplicità” set forth by the Head of Group Design, Walter de Silva.
    Outside, the customisation includes new wheels and brakes as well as new bumper designs. In front, three very large air intakes characterise the Golf R in the bumper area; the louvres on the intakes are painted in high-gloss black, and standard LED strips that serves as daytime running lights are integrated in the two outer air intakes. Also painted in high-gloss black are the two louvres of the radiator grille. Placed on the right side of the grille is the newly designed R logo in chrome. Bi-Xenon headlights, included without surcharge, illuminate the way through the night. On its sides, the Golf R is identified by its Talladega wheels, side skirt extensions in body colour and mirror housings painted in high-gloss black.
    It is also possible to recognise the Golf R as an independent top model at the rear. Along with the bumper with diffuser and tailpipes, R logo and larger roof edge spoiler, the newly developed taillights stand out. They operate with standard, distinctive LED technology. The taillight covers are also smoked.
    Interior features of the Golf R
    The sixth generation Golf, with its high-end interior materials, breaks through boundaries to the next higher class. The Golf R also benefits from this quality image; it is in a league of its own based on its power reserves. Additional special upgrades developed by Volkswagen Individual underscore the car’s high-class positioning.
    A key equipment option here is the newly designed “Top Sport seat system” with its excellent ergonomic properties. The driver just sits down, adjusts the seat longitudinally and in height, adjusts the steering wheel, buckles up, and is ready to go. The seat fits as though tailor- made. Together with the similarly customised Golf GTI and Golf GTD, the Golf R sets standards here among the international competition. The centre panels of the sport seats are upholstered in the honeycomb textured grey-black “Kyalami” design – named after the race course by the same name in South Africa. The front edge of the seat is upholstered in Titan Black fabric, while the inside panels of the side supports are upholstered with crystal-grey “San Remo” micro-fibres. The rest of the seat components and the roofliner are coloured black. The new R logo is embroidered in the front head restraints as well. Motorsport shell seats for driver and front passenger are also available as an option. In this case, the centre seat panels are upholstered in the “San Remo” micro-fibre fabric. On the outside, the shell seats are covered with black leather.
    All seams of the interior are in “Art Grey”; this is also true of the decorative seams on the three-spoke leather steering wheel. Perforated leather is used at the top and bottom of the steering wheel, ensuring maximum hand grip. The sides of the steering wheel featuring ergonomic motorsport attributes are covered by continuous leather. Spokes in fine black piano paint add an elegant aspect to complete the sporty image. The centre steering wheel spoke bears the new R logo. The fascinating material contrast of piano paint and chrome conveys an image of the passion for finesse and precision in every detail.
    Other new design features include the R gearshift knob, carpet floor mats, aluminium door tread plates with R logo and the instruments with their blue pointers. Stainless steel sport pedals and R-specific instrument and door accents in “Silver Lane” style complete the customisation. Another standard feature on the Golf R is an automatic climate control system (“Climatronic”), “RCD 310” radio-CD system (4 x 20 Watt) including MP3 player plus dual tuners. The Golf R can be ordered in Germany starting at the end of this year.
    Sorry for the bible.
    ASAP AssHole WTF?'s Avatar
    Woodstock/Kennesaw
    i like it
    Slow&InControl! LokiSays's Avatar
    Its ok. Dont know much about V dubs but they kinda all look the same. just my opinion.
    Quote Originally Posted by LokiSays View Post
    If you wanted different why did you buy the most popular tuner car EVER?
    Anyway, looks good, minus that shifter thing that doesn't look like a man's shifter thing.
    Canton
    Fear not, the man shifter and pedal are an option.
    God dammit cause im broke Simon!
    But dont get me wrong the interior is FRESH!
    Certified Gearhead Shift_2WIN's Avatar
    Jul 2009
    Downtown Atl
    I like it
    Macon
    Ehhh...Scirocco plz.
    Fair enough!
    Canton
    Looks good, the paddle shifters are kinda fun in the new VWs and Audis. But the gimmick gets old.
    Try not. Do or Do not.
    The Gradies... KillTheCrow's Avatar
    Ooooooo...... Ahhhhhhhh
